By Kingrex in red
I would expect superb execution from Shunyata. Agree The one thing I don't get is why with a device like the Altaira that is dumping noise into the house ground via the wall duplex, with (presumably) circuitry that prevents reverse contamination, If its presenting reverse contamination, how is it dumping voltage. Or do you mean noise from the earth ground back to the Altaira. And if each outlet in the box is isolated, why do I need multiple boxes. A friend has 3. One for amps, 1 for digital, 1 for preamps. He says its better as you add more boxes. a "Sigma" grounding cable for example would provide a bigger audible improvement than a "Venom" grounding cable. I have the same question with regard to Entreq for example which dumps the noise into a box of minerals (simulated rod in the soil). I though the minerals we lacking electrons and looking to pull them from the attached equipment. They offer a hierarchy of grounding cables at different prices, but I have not heard/seen an explanation of why different conductor metallurgy, geometry, shielding, etc. impacts sound quality in a circumstance where noise is presumably draining in one direction only. Not saying higher end grounding cables don't make a difference, IF you have stray mV you want to give a path to some place, that path would need to be highly conductive (silver) with low capacitance. Geometry and material could very well matter. I would just like to know why they do. Same here. Why on earth would a parallel path from the signal to earth ground not create a ground loop with ground in the power supply.
