Hi
Specs do not tell all the story. For most here that seems to be the opinion. They do however tel part of the story. I would like the gurus to chime in on Specs, their truthfulness and how they can be used as a guide in choosing components.
While many (most) here at WBF rely on audition for final determination, the reality is that this has become increasingly difficult to audition gears. A good way to interpret and find the truth within even published specs would help.
The idea of the thread came to me in an ongoing debate about FMA amplifiers. A. Wayne pointed something I never really consider: Most so-called Class A SS amps slide (unadvertised) to Class B so that they can "double down" ... Big names, big amps et all most double down amps don't (can't) do it down to the lowest loads in Class A ...
Same for speakers. Most are not as sensitive (I prefer to use the term "inefficient" but microstrip is keeping me straight so .. ) as they say they are . And many 90 dB speakers are actually 87 or even less ...
Another important specs is the input sensitivity of amps, most amps are 26 dB gain devices, many are not some are 32 dB or some even more ... Input impedance of an amp is another needed parameter for matching different technology or brands (say tubes preamps with SS amps, etc) . Same with impedance matching between amps and preamps.. Not as straightforward as it would seem .. as some amps impedance characteristics vary with frequencies (same with preamps). FR of devices are often load dependent .. All this would help determine n advance the matching of equipment. Since I am in a good mood I will use the audiophile overused term "synergy".
Rise time (important in my opinion but not as much as settling time which let me know about the time the component takes to settle back after a pulse, important in my estiamtion inthe way the amp reproduce a short pulse without oscillation, Slew Rate etc
What about power ratings? Peak output versus Continuous?
Specs can help and a way to interpret them would help many of us. What say you , the experts? I know we are asking a lot as books could be written on the subject of specifications. An ongoing discussion can only help. Questions , answers, replies and clarifications are welcome and helpful
