At 1 ohm , most may smoke like one .....
One has to be careful when comparing double down specs, amplifier distortion rises for each halfing of impedance, because of such most will give the distortion spec into the lowest load when quoting power ratings and distortion.
for eg.
.1%thd
8 ohm 200watts
4 ohm 400 watts
2 ohm 800 watts
while others will state
.0001thd @ 8 ohm 200watts
.0001 @4 ohm 300 watts
.0001 @2 ohm 500 watts
but if they gave their distortion factor the other way , at .1% the amplifier would appear to double down in ever load. What is best is to compare distortion numbers and to make sure power is increasing as load changes and not the other way , which would suggest a weak PSU for low impedance operation ..
If you look back on the measurements previously posted for distortion vs power output, you will see a knee as distortion increases, technically this is the max power for best sonics (at knee) not at the reported 1%(SS AMPS) but at the apex of the knee , for this reason TUBES can sound as loud as their SS counterpart with half the power, because their distortion is less objectionable at max output as an SS.
So yes a 200 watt tube amp can appear to play as loud as an 400 watt SS amp ...
Regards,
for eg.
.1%thd
8 ohm 200watts
4 ohm 400 watts
2 ohm 800 watts
Regards,
