autocorrect and auto-tune. Both crimes agaisnt humanity.
amen!
That's a very logical statement, Max but is that what's happening? Look at Amir's description of how he felt doing the ABX test. Do you think that any of these factors might influence the test? Do you think these were new factors not there during normal listening?But clearly the more variables you remove, the more valid the test. Why then would sighted tests be better than any form of blind tests in terms of identifying differences?
So did this test involve just removal of one variable & nothing else changed?Put another way, there is something to the fact that when testing for small difference, and the outcome being some kind of race that is scored online, and needing to achieve perfect score, does create an abnormal situation relative to how we usually enjoy music without having to report on it. Instead of the test being purely about what we hear, a lot more gets involved beyond just the ear.
I'm sorry, Max, - if you don't understand how discussion works? If you don't understand my points, feel free to ask but simply stating your question again gets us nowhere.John, I asked the question and you replied with five more questions
I'll ask it again in the hope that you might answer it. We can then analyse what's what.
Yes if you are looking to prove something, it is necessary to have valid testsJohn, I think it's easy to allow these kind of discussions to get unnecessarily over-complicated and confusing, so I'll try to keep to the point that's been our main focus of debate of late in this thread.
You state that only tests that account for every possible variable imaginable are valid.
No, I didn't say "are also valid" - I said have other strengths that blind testing doesn't - quick A/B switching is concerned with spotting differences that rapid switching can reveal. There are other differences that rapid switching will not pick up but these long term listening tests haven't been done properly, AFAIK (Nousaine's article on this had a flaw or two).You also state that long-term sighted testing can reveal differences that properly controlled ABX testing cannot, and thus are also valid.
quick A/B switching is concerned with spotting differences that rapid switching can reveal. There are other differences that rapid switching will not pick up.
How many people do you know have picked their equipment using a valid blind test? More likely that many people use forum-based reports of blind tests, think they "prove" something like all XXXs sound the same & then stupidly buy any XXX.
So, here's my summary in bullet points:
- Valid blind tests are non-existent in audio forums
- ABX testing is much more controlled than the above but still leaves out control over some factors
- rapid A/B testing is good at revealing certain types of differences but not necessarily all
- bearing the above - long term sighted testing has advantages, IMO, - it's our natural way of listening (at home on our system) so we will have a better idea of how we will enjoy/live with the equipment being tested.
I liken this to buying beds or sofas - I would much prefer to have a service that allowed me to take the bed home & sleep on it for a couple of weeks than to try testing it in a shop -I just know that I'm gambling when testing beds by spending 5 (or 30) mins lying on one bed, 5 mins lying on another. Same applies to sofas. So can you tell me that living with a bed or sofa & being able to give it back wouldn't be a better option for deciding which you will purchase?
So is long term sighted testing valid or not?
Does it control all variables, no! So therefore not valid
Is it just as useful as the blind tests that are bandied about on forums - more useful, IMO.
Does it give us a better handle on how we will like a device/system/sound over the long term - yes!
Is it better, in this regard, than A/B testing - yes, IMO
answered - see Whatmore postAbsolutely, though our ideas of what's valid differ.
So long-term tests are not valid?
OK, you are saying that rapid A/B switching is not part of the testing & yet it is claimed that rapid A/B switching is the best way to identify differences. A bit of a problem, don't you think?Same system, same music, same sound from speakers - the length of time one may sit in front of them does not affect the output of the speakers, and rapid-switching is only one element of short-term testing - you can also listen to sections of songs, or whole songs, during short-term testing.
Ok, so now you want to change the stated advantage of A/B testing (rapid switching, which means eliminating short auditory memory issue) & change it so that it matches long term listening - just to prove a point. Kinda getting away from all the stated advantages of rapid A/B switching, isn't it?There is no reason why long-term listening will allow one to hear differences that short-term testing will not. To believe so is faith-based.
Yes & I know that different DACs, Amps, etc are different & sound different!But you know all the different beds and sofas are different. Remember that audio testing is concerned only with differences, not preferences.
What about long term non-sighted tests?
OK, you are saying that rapid A/B switching is not part of the testing & yet it is claimed that rapid A/B switching is the best way to identify differences. A bit of a problem, don't you think? Ok, so now you want to change the stated advantage of A/B testing (rapid switching, which means eliminating short auditory memory issue) & change it so that it matches long term listening - just to prove a point. Kinda getting away from all the stated advantages of rapid A/B switching, isn't it?
John, I'm simply pointing out how short-term testing can replicate long-term by way of being able to also listen to sections of music, or whole songs, as well as being able to rapid-switch. What else can long term cater for that short term cannot, in terms of looking for differences?
Bit of an umbrella statement there, and I think believe rather than know might be more apt, but fair enough
As I said before - we don't make good human instruments so I do my audio testing usually to find out which I find better, which I prefer.
Cant argue with that, whatever works for you, etc.
I think most people are not involved in the form of audio testing (human measuring instruments) that you are talking about
The kind this thread is about, and we're all talking about, you mean![]()
I'm finished with this - I think you know what the answer is & don't need to ask - uncontrolled variables = what?
I'm not, Tim. I was asked a specific question - "Is non-sighted long-term listening, VALID" I countered "I think you know what the answer is & don't need to ask - uncontrolled variables = what?"This.
John, you seem to be arguing broadly against blind listening,
We disagree. Good enough for you?
Tim
Anyway, let's leave that be, OK?
Tim, you agreed to disagree on page 26 when you posted:
And as I replied then & would ask you to please accept again
