Steve williams
Site Founder, Site Co-Owner, Administrator
The K2HD is the way to go IMHO the SACD was a huge disappointment.
Not so sure about SACD however like you I do enjoy my recordings done in K2HD format
If not, in a pinch I have a copy or two of the original. Only problem is finding themI don't personally have the RTR master dub of that performance, maybe Bruce does?. however; I have the Classic Records 45rpm box set which is outstanding. it's among the very best sounding 45's I have.....and I have the Hybrid SACD (I cannot remember how good it sounds it's been so long since I listened to it).....I may have the dsd file too but cannot remember whether I do or not. i'll look thru my server to see.
I do also have the Classic 33rpm vinyl of this.
Jazdoc likely does have an original pressing. in this case i'm betting the Classic 45 rules.
To call this system purely synchronous is misleading IMO, suggesting that the reading of data from the CD has a link to the jitter at the output. As you later say, it doesn't, but as I mentioned, someone determined to find a use for a $1600 CD could home in on 'ground related issues', hence my description of completely separate transport and DAC, plus extra buffer.
If not, in a pinch I have a copy or two of the original. Only problem is finding them![]()
i have a couple early copies, but likely not original pressings. they are nothing to write home about and my 45 set is far better. but then, in the case of the Classic 45's verses original shaded dogs i prefer the 45's in every comparison i have done, and i even typically prefer the Classic 33's to originals, but that is much closer and more a matter of preference.
first; Tim.....you should come to Seattle for this.....I will even contribute to your plane fare fund personally.
second, my only reaction to your request for blind testing is.
I don't want this thread to decend into that discussion.
I do promise to do blind testing for sure if you show up.![]()
Actually, it's nothing new. Robert Harley reviewed one in 2009:
http://www.theabsolutesound.com/articles/the-2000-cd-made-from-glass-1/
and I first heard one by Winston probably around the same time. Glass masters have been in use since the first CDs were stamped , but these were extremely delicate. It was the development of shatterproof Gorilla Glass by Corning that made these possible as something that can actually be sold to consumers. AFAIK, a glass master costs from $600 to $1,200 to make, depending on the plant.
Just like if you ever had the chance to compare a lacquer and the eventual pressed LP, the difference between the glass master and the actual pressed CD is night and day. The difference is that a lacquer would deteriorate at every play. The glass master won't.
$1,600 for music embedded (pitted) on a disc made of crystal is one thing; there are other things going on right now, on our planet, that are much much tougher to digest.
Mike, when you say you have a couple of early copies, but likely not the originals, are you talking about the original 1s1s pressing? As you know, not all of the 1s1s pressings are the best pressings of a particular album. As an example, the 10s 10s pressing is many times to be preferred. I will look and see if I have a 1s1s pressing of Belafonte.
No luck, not a big Belafonte fan...I'll turn in my audiophile badge at the demo!
Is there a crystal disc of Opeth's "Damnation"?![]()
i will have to lay my hands of those pressings to answer your question. by early i simply meant a shaded dog and not a later reissue. not that it had an early number.
i know it is a shaded dog, but not great sounding relative to my Classic Records pressing. beyond that any specifics would be a guess.
i know i never pursued any specific early
Mike, you might want to check which pressing you have, There are 'white dog' pressings out there as well as lower number 'shaded dog' pressings ( BTW, on the popular series, the "white dog" can easily be mistaken for the earlier "shaded dog" ) . The SQ varies greatly as to which copy. IMO, the earliest number "shaded dog" is the best followed by a later number "shaded dog" and lastly the "white dogs". I think the 1s 1s "shaded dog" is a superb recording and easily on a par with the Classic re-issue.
