But you are also very high up there in that regardAnd the one field where you outshine us all Tango, you sense of humor
ok. 2 posts and now 3 PM's all asking me why not the Vyger? i guess that it's not going away, especially if i ignore it.
the Vyger came in second place. price was not a factor. i personally have only heard the Vyger at shows some years back a few times but honestly never paid close attention when i did. and had never heard the CS Port. so this was not about what i heard. it was the usual collection of small things and a feel for what i would prefer.
so i am not going to strongly defend my decision at this point, just acknowledge that the Vyger deserved to be strongly considered, and it was.
if CS Port had not run that ad in the September Stereophile this thread could have easily been about the Vyger. and i would still personally recommend the Vyger strongly based on my investigations. i have no illusions that that will satisfy the assembled masses on this issue. but i reserve the right to not comment further about it. not wanting to cast any negativity on any fine product i did not choose. and there are many.
no vacuum hold down makes listening to music so much more enjoyable imo.
Curious, what do you mean by this? I’m using vacuum hold down for the first time and now can’t imagine having a table without it.
either the above is true, or your comment below is true.....but not both.
no; those thin air films 'decouple' at higher frequencies. the granite plinth dampens lower frequencies.
their choice of the word 'integration' means that the plinth and platter integrate to reduce resonance. their tolerances and mirror image allow for thin air film for optimal effectiveness. the product of which is low noise. integration does not = coupling.
my money and ears tell me CS Port has it right. or....maybe.....i'm failing to understand your meaning. would not be the first time.
So Mike, on the subject of vacuum hold down...all three of yr tts don't feature this. Do you feel you're missing out at all? Had you gone Vyger, you'd at least have had one tt w this function. Maybe you're not a fan.
putting the record on, putting the record clamp on, pressing the vacuum on, start the table and finally listening - then reverse to take the record off. PITA if you ask me and the main reason why I have never considered the Air Force tables.
vs
put the record on the platter and listen.
my two Jap DD tables get to 33 in less than a second and my belt drive I leave spinning when listening.
ps, I have an ORB record flattener so no issue with dished/warped vinyl.
No requirement for vacuum or record weights - they all add their own coloration.
YMMV
No Mike, both are true - the platter does not ring like a bell because it is acoustically coupled to plinth. The energy from the from the tap is drained to the plinth. My point is that the thin air film does not isolate, as we usually expect from air, but couples the platter to the plinth. And yes, it is the right way to dampen the platter!
I can't believe i missed this thread. I didn't recognise the TT so didn't click on the thread. Congrats Mike. Looks great and I bet it sounds lovely too.
Another way to dampen a platter is through mass. For instance, the AS2000 platter seems much heavier and it too is supported by a thin layer of air. I wonder if David thinks of the air bearing as a way to dampen the platter, or primarily as a way to reduce bearing noise, or something else.
When I think of "acoustically coupled", I think of some speaker/room boundary scenarios with front corners playing a role in bass reproduction.
I also think of the layer of air under linear tracking arm wands. I always thought of its primary function as reducing friction. Is it possible that it also acoustically couples the arm to the rail and dampens arm resonances? I'm just thinking out loud here and maybe just full of hot air.
thank you Howie.
CS Port is very obscure, below most people's radar, as is their turntable. i'm sure many passed over the thread as not relevant.
and yes, it does sound lovely.
Mike
Mike, I totally understand your desire for a belt drive + linear tracking tonearm topology, and you bravely were willing to proceed with a new and expensive turntable without local designer or dealer support.
Looks like retail in Japan for the entire package with all the options is $35,200 USD.
