I'm always amazed when people render opinions on the sound of a room by looking at a picture.
As a general rule I would agree. However, some rooms just scream 'hideous' and you don't even have to have psychic abilities when you see the picture.
I now have almost 400 hours on my pair of Shunyata Alpha High Current power cords and I have had much more time with critical evaluation of these cables
What I am finding is that they are incredibly neutral across the sound spectrum. I haven't been able to compare these cables to the Anaconda but have been able to compare the cable to my prior Nordost Valhalla. IMO the Valhalla seems to be extended in the treble as compared to the Alpha HC, so much so that as I have said before the Valhalla seems bright in retrospect when compared to the Alpha HC. Where I have found the biggest bang for the buck in the Alpha is that the bottom end and mid bass is far more articulate and better defined than the Valhalla.
I just find that this cable at $1250 is such a bargain that it is difficult to pass up an opportunity to audition it. Jump at the chance if it comes your way. It really is that good and will perform well in any system. This cable needs many hours of break in before the magic becomes evident
Caelin just said they are $1250 and I amended my post accordingly
OK. I just ordered a pair. Should have them in a week or two - then burn in for say 10 days and Anaconda shootout early March.
Based on this thread and conversations with Caelin, I've ordered 2 Alpha HC, 2 Alpha Analogs and 1 Alpha Digital.
I received the 2 Alpha Analogs yesterday but the other three will take a bit longer.
These will be replacing MIT ZIII's (assuming I like them better).
I'm really looking forward to trying these!
You got me thinking may be I should throw in an alpha analog with my order to try on my pre-amp (currently using anaconda as well....).
What the hell. Ordered an Alpha Analog as well. Anacodas may be on the way out, with the exception of umbilicals.
Steve -- After your Alpha digital power cord has been burned in, you may want to try your Playback deck directly into the wall outlet, bypassing the Triton. I have found better performance (more open highs and mids) by doing so with my Spectral 4000SL disc player. It will cost you nothing to try and may net an even better result. I know that it is very equipment brand dependent, as my Audio Research CD8 sounds better with the Alpha Digital into the Triton. Again try both ways! Happy Listening! Best, Rob
Not necessarily better Frank. Perhaps somewhat different but the price differential on the two cables is what has people thinking
