Ortofon sells their scale here in the US too.
david
Hi David
I thought the scale Ortolan sells in the USA is accurate to 1/10 of a gram whereas that sold in Japan is accurate to 1/100 of a gram
david
I have the top digital scale only available from Ortofon in Japan. I just went down stairs and dropped the stylus on the scale and moved the VTA up and down from level. Raising it makes the VTF lighter and lowering it below level adds weight. It turns out we are both right. I can get the VTF to change up to 5/100ths of a gram by going to the extremes of raising or lowering the arm. Of course in real world use these extremes do not happen so if you are in the level range going up or down, for all intensive purposes the VTF remains consistent. I tested this on both the elite and supreme arms. So I stand corrected. I can get the force to change a little but in real world use, it doesnt matter. I learned something today.
Thank you for following up. This tells me that the arm is just a tad into stable balance outside a practical range of arm heights, so though not dead nuts neutral, it certainly can be claimed to have neutral operating balance. The only arm in my experience to be dead nuts neutral was the arm on the original Acoustic Research turntable, a feature submerged by the arm's other problems like sticking of its vertical viscous damping provision. If I learn anything new from Bob I'll let you know, unless you get to him first.
david
Hi David
That old war horse is pretty good, almost as great as the Sheffield direct to disc drum record... Almost![]()
Yes.
With the Basis WoA Ron will be saying, "Warp? What warp?"![]()
I have not heard the M&K but I have the Sheffield and use it often to evaluate changes in my system and the dynamic capabilities of other systems. It is a real acid test LP. Steve, are you familiar with the Sheffield?
