What was it like Ked?Lol - had the Aavik for home demo for 2 weeks - back last summer
Keith
I would rather use the Devialet if I wanted to go integrated
This is what I thought. Blizz - in the interests of being future proof, I would have thought that the Lampi or Aavik approach makes a good deal of sense since I assume the processing power and the statistical algorithms behind the software based approach are only getting better. Imagine Hqplayer "HD" in 5 years - what will that achieve only with "standard" quad upsampling.
So this opens my next question. Is it the quality of the upsampling that is key or the actual numbers (2x, 4x, 8x, 16x etc)? I would argue the former based on listening. Hqplayer upsampling PCM to double dsd sounds better than jriver upsampling to quad for example - thoughts?
You had the C-300 that was just unveiled at CES? As for the U-300, I don't blame you. 24/192 PCM max capable, and mediocre Pascal Class D amps. Not my cup of tea.
Oh right, I had the U-300 - but it is not only a dac, also an integrated amp, and I tried it direct, with Lampi in, and with a Sony SACD player in. Not for me
I am interested in the original question still. How far to go with DSD? Sooner than I expected now someone makes a 16x DSD or DSD1024 machine. I understand the possible benefit DSD128 has over 64 as it pushes the noise further from 20 khz. After that what are the higher rates accomplishing that the lower rates don't do adequately? Anybody have some idea?
Most say after quad DSD the benefits are inaudible. Better to work on loose ends elsewhere in the chain.
Okay, so what does DSD256 do that 128 doesn't? Why does it sound better?
Does accepting higher rez data means the FPGA device in the DAC has to "do more work"?
Better attack transients for me. And that has many implications for overall sound, including timbre accuracy and soundstage.
Yes, but there's different levels of filter algorithms that require different levels of processing power. So, just because it is a higher sample rate, doesn't mean it took more computing power to preform the task. For example Hqplayer has a pile of different algorithms for the upsampling/modulators. some require little power, and some much more. But the best sounding ones require the most power. That's the drawback with using an FPGA. they can offer firmware updates, but before long the FPGA maxes out and makes it impossible to further upgrade. This is why in the EMM Labs DAC2X they had the MDAT1 DSP, and now they have the MDAT2, which required a complete new $25000 DAC, with more powerful FPGA. If the DAC was just made to process the DSD filtering end only, upgrading to the new filter algorithms would just be a free update from HQplayer. Eventually you will need to update your computer, but most people do that every 3-4 years regardless. Not only that you will never be able to process the level of algorithms on a FPGA, as an powerful intel processor. The algorithms that run on the EMM Labs DA2 for 16x DSD upsampling wouldn't even make an Intel processor flinch.
Here's the obvious questions:
Does loading the FPGA device with more "work" means chances that it places more demands on the power supply of the dac/player, thereby could potentially affect sonic performance?
Do FPGA devices generate noise radiation - and that running at higher demand on its capabilities generate more "noise"?
Does it also means that upsampling 44.1kHz pcm to dsd may actually end up affecting noise and power supply loading issues?
I think you are confusing soft with bad soft. It's like a good sacd. It sounds more fluid. Good DSD is also much better mastered. The dsd I have of Mahler 2 is still the worth keeping digital for even if someone had 30000 vinyl
