I recently purchased a pair of pre-owned Sonus Faber Sonetto III, currently being paired with an Arcam SA20 integrated amp. Prior to the Sonettos the Arcam was driving B&W CM5s which are an exemplary pairing. So I've had the Sonus Faber's for about a week and have run them around the track with a variety of my favorite music, primarily blues and jazz and I'm underwhelmed so far. I've listened to them with an SVS SB-2000 sub switched on and off. The sub is set at 50Hz, volume is at 25%.
I've played with positioning and toe-in and positioned GIK bass traps in various areas of the 14' x 14' room. The Arcam is rated at 150w into 4 ohms. The SF are 3 way 4 ohm speakers rated at 89dB and 50 - 250w so my amp lands square in the middle. I'm not sure if I should be asking my dealer to test out different amps at home or the speakers are just not my cup of tea. What I like about my CM5s are their punchy 50Hz output, smooth midrange and crystal clear treble with only the occasional offensive sibilance.
What I don't like with the SF are what sound to my ears like veiled mid to upper range. Most of what I play (hi-res streaming) just sounds dull and lifeless. Maybe my ears haven't adapted to the very different speaker sound signatures but I don't think so. Do I have an inadequate amp problem or a speaker problem? Thanks in advance for your expertise.
