EMIA Transformer
Kcin
664
859
275
Canada
I've got the Ag EMIA here for evaluation. If it works it will stay. It will be part of the phono set up with the AG Autoformer ( truly excellent) from Slagle.
I will try it with my standard Io and some other phono stages in house. Lots going on.
thekong
254
146
948
Hi Kcin, any feedback on the Ag EMIA transformer? I am planning on getting one at 1:10 for my EMT cartridge.
Thanks
Kcin
664
859
275
Canada
Thanks
Hi
@thekong
I used the EMIA up with my Io and the Klyne in many different gain configurations. For my system the straight active was preferable for a number of reasons. Having said this, I have a friend that uses it with with his Kondo phono with Goto horns and loves it.
If your system requires a SUT because of the nature of your cartridge phono interface- its probably one of the best options out there and Dave is very enthusiastic and helpful.
You really have to try. On the other hand, I use the Slagle silver autoformer box and I am in love with it..
YMMV.
Reactions: thekong and bonzo75
thekong
254
146
948
Thanks Kcin for the information, appreciated! I won’t be using the SUT with my Io, but plan on pairing it with a LCR phono built by my friend!
