Well in a word :: no.
What Neil Muncy, Ralph Morrison, Henry Ott and Jim Brown write about is signal.
I was commenting about the Tripoint link, not sure how it can do signal ground when it uses mains but sorry if I misunderstand their product.....
The other picture reminds me of a Signal Reference Grid?
Speedskater said:
I don't know about Josie, but yes, unbalanced RCA is a flawed concept.
The AES and the pro audio world have little interest in RCA-unbalanced cables.
Glad we agree about unbalanced RCA, and I think I am more in alignment with you than you know in principle but personally keeping an open mind to the concept for the Entreq solution, difficult to call it an architecture or even a solution when do not know everything about it and someone needs to test-analyse it further if all the discussion in this thread are to go further, but it still could be working (and way setup I tend to feel it quite possible).
Well it does interest them because they made a recommendation regarding unbalanced cables as a correction to the implementation of terminating shield only at source end to overcome issues.
The pro world is interested because there are cable manufacturers that focused on the pro workd initially or combine that and consumer these days; Mogami/etc all do unbalanced RCA, with Van den Hul still offering single side terminated cables for shield only to source (although goes against AES recommendations).
Speedskater said:
This quickly becomes a balanced/differential interconnect system.
We should also note, that if you connect ground box cables to unused, insulated RCA chassis connectors, you have created a great interference antenna.
I did mention RCA only, and it possibly only matters for true balanced stages and components (where I am like you wondering how it might work but keeping an open mind - they still have unbalanced connection).
Unfortunately the RCA inputs are all active in this context (0V signal ground reference) so not sure what you mean by antenna caused by this solution.
If it was causing antenna related issues this would had been noticed very quickly by many owners in causing a detrimental effect, rather than the reduction in noise that seems to be the trend of subjective listeners with music.
speedskater said:
You do it by following the teachings of What Neil Muncy, Ralph Morrison, Henry Ott and Jim Brown.
That's one of the ways that electricity works. (remember that impedance thing?)
Nothing said so far has actually touched on implementing this in an audio unbalanced system involving multiple components connected with RCA and with the signal ground
not directly connected to chassis ground (by this I mean some isolation that does not break the health rules such as using diode bridge among others I touched upon earlier).
I agree it is slightly unusual (please note I am not defending Entreq but I think some are jumping to sceptical conclusions) in creating the external 0v signal input star ground/return path that way but it is safe and may work.
speedskater said:
If the box does act as a filter, which I doubt, then it's converting the noise to heat.
Agreed that is my point in response to Josie and unfortunately we cannot say if it is also acting as a filter or not, I was tempted to mention ferrite but someone probably would had pointed out how when used as a collar it also reflects noise and not just converts it to heat
I think we are all going round in circles
Caelin says it best IMO.
Cheers
Orb
