G'day Trebor,Big Dog RJ. Looking at purchasing the K-07XS. Do you find the transport is quiet in operation, when loading and playing discs? I sit close to my kit so it needs to be quiet.
The K07-XS does have a slight mechanical/ motor hum. When loading discs and start up, it's like a jet engine revving up. Which in fact I find quite fascinating! It's sort of cool to me, and I'm not bothered by it one bit. Once in full operation, it's pretty quiet and runs smoothly.
Having said that, the quietness factor is not a criteria for me for determining good quality sound on recorded music. I've used far much quieter gear and they were no where near the Eso. Just listing in backward order, some I can't even recollect: Mac, ARC (Ref series), Cary, Cayin, McCormack, Wadia, Meridian, Copland, BAT, CJ, Arcam, Musical Fidelity, Marantz... the K07-XS surpasses the lot by far!
The only ones which were great were partnered with DACs and they sounded quite good but again nothing compared to this particular all in one from Eso. Given the features, settings and digital filters, plus the various outputs / inputs to match its DACs chip sets, is one heck of a design. It simply outweighs that quietness factor, it doesn't bother me. I guess sitting away over 15ft obviously helps.
The K05XS is very similar in construction and weight, it offers pretty much the same thing with a slightly modified transport mechanism. I compared the two side by side, and honestly couldn't tell the difference. Or shall I say, the extra spend involved was not justifiable. These two units are the starting line-up for Eso. When you get to the K03XD series and above, this is where changes take place significantly. Such as the power supplies, DAC chip sets, more digital filters and settings to choose from, basically things get far more complex. In addition to this, the overall weight is quite different. With the K07-XS & K05-XS units, the weight is around the 20-22kg mark. Whereas the XD series and leading upto the K01 and so on, the weight is over 30kg... this added heft gives more stability and solidness to the transport mechanism and whatever else is operating internally.
The list I've mentioned above does not include exact model numbers, rather the names. From that list, the Wadia with the Meitner Dac combo was the most natural, as well as the CJ DV2B (vacuum tube CD player). However, all of these units are no longer in production. In fact, the Mac, which was the last one I used, outlasted the ARC, Cary and Wadia put together. So when the time was up for a change, I was looking for something that is solid, well built and something well worth the investment. Not just another top of the line fancy price unit that was highly reviewed... not my gig.
It has to gel well with the rest of the gear, especially when considering CJ amplification with CLX's, and that synergy is so important, regardless of price. It certainly took a while to find the right fit, and I'm extremely pleased with it and what it offers. In terms of vfm, the K07-XS is one phenomenal digital playback system.
When partnered with the right gear, give it some time to settle in, choose the right settings and it will deliver some fine tunes!
Speaking of quietness, if that's your main criteria for justifying sound quality and performance, there's one that is so quiet, you can't hardly tell even if the disc has been loaded or not; the Luxman D10x. It just glides like an eagle... absolutely amazing mechanism and dead quiet. It's a another fine player and will deliver a very highend performance, as it ought to since it's Luxman's top of the line.
However, if I were to look at that and then compare it to Eso's top of the line, that's a serious challenge we're looking at. To me, the Eso gear are in a class of their own and the top level stuff is very pricey in Aus. Nonetheless, doesn't necessarily mean that Eso is the greatest and latest... definitely not. It's something that you may have to try out, see if you like it, check how it matches with the rest of your gear, and whether it improves the overall level of playback from your system. Not just better quality sound, that you'll get with any latest generation player. The key is how far a margin has the quality factor jumped...
My finances don't permit that absolute top level just yet, and if I were to upgrade from this point onwards, it will be the G01-X clock. That makes a significant difference and within my personal benchmark of 40% in improvement. Now that's justifiable to me, however the G01-X clock by itself is three times the price of the K07-XS... !
I wanted to try out the flavour of Esoteric's line-up, and now I understand what they're all about. So, might as well be happy and satisfied for now, I truly am!
Let us know how you go, and what you decide on.
All the best in your search and auditions, hopefully you'll find the right fit.
Cheers, and enjoy those fine tunes!
RJ
