These would lead me or anyone that you are talking about audio amps and not the intrinsic qualities of tubes
Is there audible latency in amps? [...] What does it sound like?
We refer to latency as 'smearing', there are probably many sources for it in a circuit, and one manifestation of it is in the squarewave graphs. I suggest you read the Soulution reviews in TAS, or Hammer's interview in issue 223, where they talk about their efforts to address negative-feedback-induced latency which affects the overall sound. I don't have the issues in front of me, by I vaguely recall them trying to drop this down to 2-5 picoseconds or thereabouts.
The Atama-sphere MA-2 OTL has a rise time of 600 volts/ms
Is there audible latency in amps? If you're not playing the instrument into a microphone, then hearing it played back through the system so you have a point of reference, how do you even know there is latency? What does it sound like? When I think of slew rate, or "speed" in an amp, I think of the very clear, crisp attack of percussive transients. But after reading "the speed inside the note," I'm not sure I know what you're talking about at all.
Tim
Simple latency (constant group delay) would not cause "smearing" as all frequencies would be delayed equally. I find it hard to believe any audio amplifier on the planet would reduce latency to the 2 - 5 ps range.
OTL as I noted can have that fast rise time because of the lack of Transformers.. That's a very fast rise time if the ms stands for microseconds which I believe it is ... Few SS aside from the Spectral, krell and Glodmund (some others?)of this world can claim this Speedy Gonzales speed... To repeat: aside from OTL, Audio Tubes amplifiers are not as fast on these objective terms as SS ... Even with OTL There remain the subject of settling time which is one aspect of "fast" and "speed". It is nice to rise but it is as important to stop when the signal is no longer present... and there the Capacitive nature of OTL outputs could be a problem. I don't know for sure .. Don Where are you when needed? MIA ????
In the smearing is allegedly due to the delay of the loopback (negative feedback) itself; I think they explain it really well: the signal at the output at time X (now) is being fed back to the input, and while this loop completes, time has passed and the output is further ahead. Now, whether that claim is all true or not and to what extent, I'll leave it up to others to analyze. But *if* the waveform at the output is affected by any delay in the negative-feedback loop, then to me that would be smearing...
[...] This lag results in ringing effects and enhancement of the odd-ordered harmonics that the human ear/brain system uses to measure the loudness of a sound (specifically the 5th, 7th and 9th harmonics).
Atma-Sphere
too much speed has issues though as well. over damped SS doesn't sound realistic to me---too much leading edge another way to put it and not enough of the whole note.
So you're saying the amp can actually rush the beat?
Tim
I have no idea what that means.
I said the whole note isn't present because of accentuated leading edge.
