In my case the preamp is a big improvement. c10x Luxman into 2x M10X's. Bass and dynamics improve
Do you mean a sound quality improvement or a features improvement? I'd be devastated if I spent the sort of money the MU2 costs only to find that its preamp was of under-par sound quality. I'd expect it to better any external preamp that requires the addition of an extra cable. We all know that cables can never improve sound quality!In my case the preamp is a big improvement. c10x Luxman into 2x M10X's. Bass and dynamics improve
Agreed. And when you are using a preamp and amp from the same manufacturer, you are maximizing your chances of an ideal match. However I would lower your estimate to $12k (MM Makua in the "crazy good" category, IMO).The pre section in MU2 is crazy good for an all in one. I’d reckon you have to be in the 15k plus range to notice any improvements. In my case I am using Dragon ICs so YMMV
if you try one at home (with return privileges, of course), I suggest asking how many hours are on the demo (300 or so would be beneficial). Also suggest keeping it on for the entire demo period. Will take at least a day to warm up.Do you mean a sound quality improvement or a features improvement? I'd be devastated if I spent the sort of money the MU2 costs only to find that its preamp was of under-par sound quality. I'd expect it to better any external preamp that requires the addition of an extra cable. We all know that cables can never improve sound quality!
Big myth going on regards of CPU it depends how much you Interfere with down-/upsampling (Roon MUSE)! What is always an issue: too large local music library and therefore too many titel/album meta-infos needs to be loaded. Higher CPU: more power consumption, more noise, much more implementation efforts...look at Taiko & CoThanks to all of those who provided feedback about using the MU2 into a seperate preamp. Now I have to get my hands on one to try out. My only reservation about the MU2 is that Roon Core is run on an i3 processor and might be sluggish on larger libraries or heavy duty processing. Any one have problems in this regard?
https://www.stereotimes.com/post/grimm-mu2-music-player-by-john-hoffman/Please provide a link, thanks![]()
on the MU1, he must have chosen the 0fs setting (choices are 0, 2, 4). But I don't think there is a way to turn off the oversampling for the MU2.Curious if anyone is using convolution filters with either the MU1 or MU2? In the review of the MU1 on Audiophilestyle.com, Chris Connaker says -
"One note of caution. I'm a huge believer in convolution for room correction. A 65,000 tap FIR filter can deliver stunning results and literally blow away the room correction solutions of yesteryear. When using convolution with the MU1 and its oversampling enabled, the sound was off. Something just wasn't right. The issue could be related to a number of things, including my own preferences or Roon's conversion to 64 bit float and back to 32 bit before outputting to the MU1's FPGA, or something entirely different. Running only the convolution in Roon and the MU1's oversampling disabled sounded fantastic. I can't explain the reasons why I heard what I heard, but believe this note of caution is warranted. I would appreciate other views on using convolution with the MU1 and its oversampling enabled. I could be an outlier."
Grimm Audio MU1 Music Player Review
The Grimm Audio MU1 first caught my eye, here on the Audiophile Style forum. Several members of the community began discussing the product in early 2020. However, a couple years went by before I realized I needed to bring an MU1 into my listening room for evaluation. This delay, from recognition ...audiophilestyle.com
I use convolution filters in Roon, so I emailed Grimm about it, and they weren't helpful, basically saying that they can't test for everything, which I found surprising given their commitment to Roon.
Thanks.
Yes, he had to turn off the oversampling when using convolution filters to make it "sound correct".on the MU1, he must have chosen the 0fs setting (choices are 0, 2, 4). But I don't think there is a way to turn off the oversampling for the MU2.
regarding the sound: "Running only the convolution in Roon and the MU1's oversampling disabled sounded fantastic." Maybe the way to find out is to find a dealer who would provide an in-home demo unit. But it seems that you already have an excellent server...Yes, he had to turn off the oversampling when using convolution filters to make it "sound correct".
suggest you read the software manual before getting the unit. If you haven't previously used a Grimm streamer, it is best to follow the manual step by step.Great thread...have the MU2 coming next week. Could someone with experience summarize the setting choices before me in connecting the unit to my Aavik U-300 integrated amp so as to use the MU2's preamp?
Greg
no personal experience. From the hardware manual (pg 15):Does anyone happen to have changed their fuse out or know what the values and dimensions are? Want to try a Synergistic Research. Anyone swapped this out? Sorry if this has been asked -was not able to find anything on it. TIA!
