Hachidori Fukami Tape/Phono Preamplifier
The VU meters on my tape player are bypassed because I don't want the signal to go through them. I have adjustable step-up transformers at the input of my head-amp. I can select gain of 3db, 6db, 9db, 12db and 15db. I like adjusting gain using a transformer rather varying resistance. I use the adjustable gain of the step-up transformers to set the level I want with a particular tape. For example, for tapes recorded at 520nW/m I use 3db of gain. If I use any other setting, the head-amp will distort. With tapes that are recorded at 396nW/m (like Ed's), I use 6db of gain. The majority of tapes I have are recorded at 320nWb, so I use 9db of gain. Occasionally, I have a tape that sounds best at 12db of gain. For each of these gain settings, I use a different resistor to load the tape head.
If I decide to use a different tape head with a different output voltage, the adjustable step-up transformers can help make gain adjustments for the new tape head.
John, just to make sure I went ahead and measured my preamp's headroom. At 400Hz it was about 26dB, with respect to +4dB.
Not from the standpoint of overloading the preamp, but high levels overload the tape, and that is easy to hear.
Why don't people learn to do it in moderation?
That’s a good question. Maybe it’s a matter of experience and listening carefully. Who knows.
I think some producers take pride in the ungodly recording levels.
That... and the fact that most of them don't use PPM meters.
Sounds like a brilliant setup.
All tape playback amps/stages should have a calibration provision. Tapes can be recorded at many levels & it's not some are "hot", but some are recorded at 396nW/m (like mine) and I've seen some from Europe recorded at 520nW/m. One technically needs to calibrate the output level of the deck to that level so that the meters can actually read the tape level properly. If your deck is calibrated to 250 & you're playing a 396 tape, the needles will be buried in the red & you will think this tape is too hot, and you may get distortion.
Most early tapes were recorded at 250nW/m. Decca recorded their fantastic early SXLs in the late 50's early 60's, at 396nW/m NAB eq.
My sense, & I maybe wrong but I don't think most outboard tape amps include an accurate calibration stage. Maybe just a click onto a few set levels, which should likely suffice.
Ed
I’ve just had this discussion with Jonathan at Hachidori and an engineer at Revox (regarding the “new” Mk III machine’s 320-510 nW/m switch).
If the preamp is designed properly, and this is strictly in terms of playback, the strength of the record level does not make a difference. You simply turn up the gain for 320 vs 510, and vice-versa. The meters will respond according to the level, so if your meters read 0dB at peaks with 320 tape, they will look like the signal is clipping. If your preamp has different gain settings, in addition to the output level, then you will want to ensure they are adjusted accordingly.
Perhaps something got lost in translation.
The recording level (and therefore the tape head output) will have the direct bearing on SNR in some cases.
In solid state circuits, and also in tube circuits with tons of global feedback, that is not going to matter. But some of us eschew global feedback, and then your SNR is directly affected by the front tube own noise, and the magnitude of the signal applied to it.
What happens after that first tube is not important.
Nothing got lost in translation. The Hachidori is a tube design, and the other design is solid state. The record level of the tape does not make a difference for a well designed pre-amp.
If increasing gain by 4dB is making tube self noise audible, I would argue that is not a well designed amp. You can make a tube preamp silent without any feedback.
If you calibrate the tape preamp for 510 nWb tape and then play 320 nWb tapes, you have a couple of options:
1) do nothing on the tape preamp and turn the level of the line amp up 4 dB to get the same playback level. In this case, the level meters of the tape preamp and the modulometers of the line amp will read 4 dB low, but otherwise there will be no issues.
2) increase the playback levels on the tape preamp by 4 dB, in which case the volume control of the line amp can stay at the same setting. In this case, the meters will be recalibrated to read 0 dB at 320 nWb, and the modulometers in the line amp will read correctly as well.
Sonically, you shouldn’t hear much difference either way.
Please read carefully what I wrote, you are not getting it.
Reactions: Robnec
Victor,
I've read of using +9 tape, e.g., SM900, but recording to it as if it were +6 stock. Any ruminations on this approach?
Victor,
Different tape stocks have different distortion characteristics during saturation, so it is not just the level at which distortion rises that is important to consider. High output tapes allow a higher margin of safety during live recordings, whereas archive tapes do not need this as the peak level is already known. There is no point in pushing the limit when you are just copying tapes, unless the dynamic range of the recording is particularly wide. I find 320nWb to be more than enough in most situations, and in fact prefer 250nWb for Agfa 468.
Reactions: c1ferrari
Victor,
I think this is good approach in general, and especially when using the VU meters, not the peak ones. But it is also the matter of how much of your music is in the above 0dB area. Random quick peaks is one thing, but if your piano "lives" there, then it is going to sound overloaded.
I have seen peaks in the +18dB area, and this is WAY, WAY too much.
My Studer A-820s are biased for SM900 and ATR Magnetics stock. The decks were aligned in preparation for live-to-2 track recording and stereo mixdown duty. Different producers and technicians have their preferred biases (lol) it would seem.
Are you using MRL 250 nWb/m ref fluxivity tape(s) to align your decks?
I use 320nWb/m for +4dB output.
But of course if you have the 250nWb/m test tape you can simply adjust by 2dB.
I use 250 for NAB/7.5ips, and 320 for CCIR at 15ips.
Yes, that is the same, I just did not mention the 7.5 speed, as I don't really use it.
I am curious if anyone has had the opportunity to try this purely as a phono preamp?
I’m looking for a new phono pre for my personal/reference system.
Another consideration is the new Aries Kirke phonostage and while I adore the AC stuff, I don’t really have the physical space to accommodate the size & weight.
I know this unit is far from inexpensive and it would obviously provide more value if I had a tape machine to use it with, but I don’t — only vinyl.
But it’s maybe the most beautiful component I’ve ever seen, and if its performance as a phono pre is commensurate with the price, and it’s as good as (or better than) the handful of similarly priced phonostages out there, then it would be justifiable to have purchase purely for vinyl use.
I have not, but mine arrives in a month or two. Dealing with Johnathan, the inventor, designer, and owner, has been an absolute pleasure. He seems to have the applied the very rare combination of both science and art when it came to developing the Hachidori.
They are also selling well - I believe he is almost sold out for 2025.
He can share owners who allow potential buyers to listen, so best to ask him. In my case, I will only be using it as a tape head pre-amp.
Why don’t you move this to a thread about this unit? This thread is about the Hachidori.
Not to mention the question was not ‘what other phono pre-amps are out there’…
