if your system is harsh...don't necessary blame your speakers or components...blame electronic hash that enters the system via the signal ground plane. It's an easy fix...Entreq !
I thought Entreq was about noise?
Entreq is about nothing, apart from extracting cash from the gullible.
Keith
What do you think contributes to harshness ? hash equals noise. I think to assume components or speakers are the culprit is misleading. I didn't think my system was harsh, but some titles in classical go on the edge. (Mercury and RCA Living Stereo) for example. With Entreq, that is no longer the case. Signal plane noise also accentuates sibilance...again with Entreq it virtually disappears.
Not simplistic. Mics, like speakers, are transducers, and have poor fidelity relative to decent electronic components. But I don't think the placement is necessarily the issue. There are far too many excellent, close-mic'd recordings to support that.
What is 'harsness' , a loudspeaker with an up tilted HF could be perceived as lean,clinical etc, or a room which allows the HF to reverberate around for too long.
Equally a rolled off HF is often likened to mellow, unfatiguing etc, measure your room acoustically and discover what is actually happening in your room.
Keith.
You realise the Palette was an EQ?
Keith
My speakers used to sometimes sound harsh and bright, but it wasn't the speaker's fault. For me, it turned out to be the quality of the supporting equipment and/or the source material. I think that some of today's speakers are so accurate, that any deficiency in the chain is exposed in all it's glory. Myself, I don't want one of those "musical" speakers that tone everything down, I want realistic.
Totally agreed, but I wonder why this is? What happens between performance and playback that allows for this change in perception? I assume that a "flat" response in the recording venue sounded absolutely fine when listening to the live musicians. When I go to concerts of live, unamplified music, harshness isn't generally a problem (although I have heard evidence of it in some smaller rooms for some concerts, which may be a question for another thread) so what gives?
It seems to me that close microphone techniques exacerbate the problem, and that recordings with a bit more space and a bit more of the recording venue don't generally sound as harsh. Naively, I always feel that an utterly flat everything from recording to playback leaves you with the sound of instruments from the position the mic was placed, and let's face it, many real instruments actually do sound very harsh up close. Is this overly simplistic?
What is the point of using spikes , which couple with a device which decouples!
Keith.
Agreed, I just didn't want to make a blanket statement that spikes are a poor choice. The one place I think they are useful is on an equipment or speaker platform that is sitting on carpet, so it has a firm foundation. Then I would place a decoupling/isolation device between the platform and speaker or component.
Is that different? You're still coupling to the floor, then de-coupling.
Tim
. . . . still points don't decouple .
Keith.
