I have received, installed and configured the D-Premier wifi card earlier on today. I could have requested my dealer to do it for me, but it seemed faster to do it myself.
- UPS has a lot to do with the reception,
- The installation should be child's play for anyone having ever installed memory sticks in a PC. Basically open up the D-Premier, push the card down its host pins, add 2 screws and close back. You then need to re-install firmware 5.5 and re-boot,
- Setting up the wifi was also easy. You basically just need to provide the configurator with your wifi network's name and password if it is password protected. The SD card then needs to be inserted back in the unit and wifi can be used after that,
- You also need to install the Devialet driver on the Mac/PC (now version 1.1).
The Devialet then connects automatically to the network in a few seconds after having selected the Air source. The Mac side driver detects that automatically. From then on playing from iTunes just uses the wifi. There is... no UI.
That must be the most user friendly and elegant wifi implementation I have ever seen.
For those... wondering whether it really works...The driver has an optional control panel that shows the state of the wifi connection, starting with how full the buffer is. So far no signal interuption and the buffer is always 100% full with close to zero packet loss.
How does it sound? I frankly thought it could not get much better than it already was with the Int202 over aes/ebu, but it most definitely IS even better. How did it improve? As always it is difficult to rely on one's memory and to phrase these impressions. I would say it is more fluid, still very sharp but somehow a bit more elastic if that means something.
Who would have thought that CDs could sound so incredibly good?
Now I just hope that Devialet manages quickly to extend the support beyond redbook to include high res files... even if it feels like a redbook played through wifi is damn close to a high res file played through the Int202.
Cheers,
Bernard
