HRS Damping Plates v Artesania Audio Dampers v Entreq VibbEaters
Ian, one could buy stock weights to place on top. Would be looking at 2.5-3kg I think. Thanks for the heads up, I'll chat to them soon.
All I can say is my HRS trial experience was a true eye opener, one of the more dramatically positive upticks you could imagine. Can this be replicated in something like this?
I cannot really try them myself. I just have six powered component and two (the Devialet amplifiers) are wall-mounted. I could try with my Triton and Typhon albeit it is a rather expensive experiment for something which already claims to be exhaustively designed. Which leaves the Antipodes CX and EX currently housed bottom and top inside a cabinet!
Yes, but only 2"-2.5" square in size. Cannot match HRS for coverage.
Icrecable suggests to use two pieces on top of a component.
And to place them with their soft bottom pattern in 90 degrees so as to modulate/decrease vibrations of two dimensions.
Too much/too heavy damping will make the treble extension less and the sound dull.
Need our ears to adjust and fine-tune.
But CK, this is not going to cover close to half of a chassis surface area. HRS works better the more area that is covered. And I can't see any mass damping effect from the Increcable. Hey, if two pieces ie $100 per component works, that's great.
Are we talking the MVD-A.I.R. or the MVD-1 or -2?
MVD-2 is the new and better entry model.
The MVD-AIR is the higher model with treble energy preserved.
CK, have you heard these versus HRS or Artesania?
Treble energy preserved has gotta be the right choice. Does that mean the cheaper models impair higher frequencies?
You would follow their advice? Ie site only one pair on a standard size component?
Yes, I tried HRS and Artesania before, but direct comparison vs the MVD was done.
IMHO the former two are expensive.
MVDs were so cheap that I couldn't resist buying some to experiment with.
All "soft" type of damping gadgets improve quietness yet affect treble energy, in contrast to the "hard" type such as Shun Mook.
CK, I remain a little confused by that. Why would you want to keep any product that damped treble in any way? Imho, HRS which also fit the "soft" category don't smooth treble in my system from what I heard at my trial.
So, does MVD-AIR perform as well or better than HRS or Artesania, or is it unfair to make a direct comparison?
I would be looking at up to 18 in my system, incl spkrs and balanced power transformer.
Sorry, I have to disagree : in my audio system and to my wooden ears, HRS does reduce treble energy.
I bought several MVDs to experiment with.
After much testing, there are now only two MVD--2 being used on my Bespoke Silver preamp.
Of course YMMV.
I guess you don't have to buy all the 18 of HRS/Artesania in one go.
Better to add them stepwisely till reaching the sweetspot.
Reactions: justubes
Sure CK, I'm a kinda "all in" sort of character Lol.
With the HRS, I was drawn to superior lower mids/bass info, kick drums being really resolved here. And the more we added, the better the overall effect. In final analysis, this meant one on Straingauge energiser, three on cdp, two each on pre and pre psu.
Certainly I would try them again ahead of purchase and look out for softer treble.
Am I to conclude you remain generally skeptical on these products, choosing to keep only two?
Found the inexpensive products I'm gonna trial, Wagner MP-4E (4"x4") and 6E (6"x6") EVA anti-vibration pads, both under $10 each. If show promise, I may go on to mass load them w 1kg inert weights.
Products used in vibration heavy environments like garage workshops. Blurb says their material properties trump cork and rubber at successful vibration mitigation. Gotta be worth a punt.
I'll look at btwn 2 to 6 pads each on phono, cdp, pre, pre psu, LPSs and balanced transformer.
Also looking at Herbie's Audio Labs Supersonic Stabilisers, potentially mass loaded again.
Remarkably the Wagner per set of 4 at 4" x 4" retails at £15.40 on Amazon.
Buy them from Increcable and you pay $80 or around £62.
Yes, I did notice that Lol.
I use those pads all over the place. Under my vinyl rack from when I had some equipment situated on top, under subs, as cable lifters. I was happy enough with them being under sources that I now run IsoAcoustics pucks under my sources and even under each leg of my Sol turntable, as well as the Sol motor.
A
Are these not meant for placing under equipment, as opposed to on top? The dampers, like those from HRS, are for the top of components.
A
Yup. They are meant to go beneath vibrating machinery to minimize noise and vibration transfer to the building structure.
Exactly we seem to be comparing two different systems of vibration damping here although of course both may be very valuable.
Reactions: toddrhodes
Guys, Increcable are marketing their Wagner "alternative" (or is that re-labelling?) as a top chassis anti-vibration aid, as such a way cheaper parallel of HRS plates.
Whether they're any good in this task, that's another Q.
