Yes, sounds really good. Have you tried playing this through your stereo? It seems that a lot of live recordings put up on YouTube that have minimal processing do a better job of capturing the "live" feel than most studio recordings or even produced live recordings. Clearly, whatever algorithm YouTube uses for compression is very good, and although probably not lossless, seems pretty much lossless.Here's a nice sounding video, the guy who did the sound, Tohid Vahid, also produced the track below in 2025 which also sounds good and much better than his older stuff which suggests recording tech is improving:
I played it on my speakers, by casting it from my phone to my WiiM Pro. The sound is ok, but you don't get the resolution that streaming redbook CD offers, IMO. It could be due to Youtube or the "casting" method, or both.Yes, sounds really good. Have you tried playing this through your stereo? It seems that a lot of live recordings put up on YouTube that have minimal processing do a better job of capturing the "live" feel than most studio recordings or even produced live recordings. Clearly, whatever algorithm YouTube uses for compression is very good, and although probably not lossless, seems pretty much lossless.
It could be that specific video then. I would have to upload a CD file to Youtube, cast it, and compare it to the same file streamed directly. I'll try it with a good quality recording.youtube use max. 256kbit sounds not worse for me. I don't known exactly that big music companies get a better resolution for extra money
I do have a subscription to YouTube (to get rid of the ads) and can stream up to 1080p, but I don't know how that relates to audio. Will check!I know when you get Pro access you have a lot options more in videoqualtiy etc.13 $/month.View attachment 146807
Only heard it through headphones so far. I will take the optical digital output from my TV and run that through my Mutech reclocker into my DAC and see what this sounds like at some point. I disagree about the resolution, at least through the headphones, compared to cd...not that I have the cd of a recording of this performance.I played it on my speakers, by casting it from my phone to my WiiM Pro. The sound is ok, but you don't get the resolution that streaming redbook CD offers, IMO. It could be due to Youtube or the "casting" method, or both.
Yes, neither do I, I was comparing it to other tracks. Will give it another listen tonight, at higher volume...Only heard it through headphones so far. I will take the optical digital output from my TV and run that through my Mutech reclocker into my DAC and see what this sounds like at some point. I disagree about the resolution, at least through the headphones, compared to cd...not that I have the cd of a recording of this performance.
I listened to it again carefully with headphones and it is very highly resolved. You can hear bowing techniques, percussion decay with other instruments playing, blowing patterns with the flutes etc. Good luck hearing most of that on a studio recording.It could be that specific video then. I would have to upload a CD file to Youtube, cast it, and compare it to the same file streamed directly. I'll try it with a good quality recording.
Maybe it is indicating what your stereo itself is missing?Yes, neither do I, I was comparing it to other tracks. Will give it another listen tonight, at higher volume...
That's always a possibility, but then why would I feel that other recordings offer more resolution?Maybe it is indicating what your stereo itself is missing?
I have not listened to it with headphones plugged in to my phone.
Yes, I don't currently have a system, just a bunch of records but even when using Sennheisers with my Samsung, Honor or Vivo phones or Macbook/HP laptops the sound goes from memorable to lift music to unlistenable.Maybe it is indicating what your stereo itself is missing?
I actually think videos like this are a good test for playback systems.
