Hmm, I've JUST invested in Rhodium Furutech duplexes, these nano beauties will have to wait for the next inexorable pull on my resources - a while yet I hope LOL!
I prefer them mounted with the ground pin up, like the lettering on it suggests. The reason is that they hold much better since they're a little soft to start with.
Although I don't have the newer Furutech AC outlets I do have 11 of the older version. When I installed mine I had the electrician mount them sideways for the same reason and have not had a problem with heavy PC's
The rest of my outlets are GTX-Rhodium. We shall see if I notice a difference with the NCF before considering upgrading the other outlets for source. I think the power amps are probably the best place to start.
I was trying to remain consistent with the way the standard outlets are in my house. I will try flipping it like you suggest.
Suggest not. Per Joe Pitman, ground wire should be at the bottom to relieve potential "stress" on the ground wire (very stiff) and make sure it remains firmly intact over time. Think about it. Makes alot of sense to me.
If you're wiring to code the wire will be supported/anchored to the wall within a certain distance from the receptacle to prevent any stress on the wiring. There should be absolutely NO stress on wire where it connects to a switch or receptacle.
The GTX receptacles are designed to play nicely with plated male AC plugs, which is why the grip isn't nearly as much as hospital grade outlets, they will scratch off the plating and actually dig into the base metal over time. GTX receptacles will not damage the plating on AC plugs. Furutech could have made the clamping force as high as they wanted, there is a stainless steel spring that provides the clamping force as pure copper is too soft.
Well it maybe true if you pull out and push in a lot of times. But how many times would you do it?
IDK.. I've seen plugs scratched all the way through the plating with ONE insertion into a new hospital grade receptacle. Truth is hospital grade receptacles ruin plated male AC plugs.
Installed 3 NCF R receptacles , replacing the GTX D (R) . These have been cooked for a week , will give them the mandatory settling in period and report back . Fingers crossed !
Ok. But I prefer firmer grip. I am worried the grip may not be strong enough that as times goes by, gravity slowly pulls the plug out partially. I have seen it quite a few times.
I quite like the new receptacles in Shunyata Triton V2. It provides a firm and nice grip.
