They just mentioned it can't be ruled out. Take it up with the person that conducted the study. I'm just reading it. If you want to get all hot and bothered over something, go right ahead. Fact is we all lose hearing over time naturally.
Myles, you are bringing up other issues trying to prove something that's unrelated to the article. Yes, we all age. But if you lose your ability to hear something while under the influence, you might want to be aware of it, and if you care, then maybe you might want to do something about it.
Why are you arguing over this article? I don't see any problem with it?
I didn't duck the subject, I don't think you read the article carefully. It said it can't be ruled out of the long term how much alcohol has an effect on one's auditory system. And?
So what if they don't know. Well, go ahead, take your chances. Just understand that it will effect your hearing while under the influence. SIMPLE, STRAIGHT FORWARD and TO THE POINT. Accept it and deal with it the way you want to.
If you have a problem with article, then take it up with the person that wrote it. Argue with them about it.
