My mac is installed on Atomic Audio Labs Mac Mini PlatformHey, I'm not the only guy who's tried it!
I placed mine face down. You?
How much does it improve performance?My mac is installed on Atomic Audio Labs Mac Mini Platform
I haven't used a Mac without a platform for a long time. But I came to the conclusion that it was worth the money spent. Also Mac is very comfortable on this platform))How much does it improve performance?
That's good. Thank you for your reply.I haven't used a Mac without a platform for a long time. But I came to the conclusion that it was worth the money spent. Also Mac is very comfortable on this platform))
Not even close.I don't see any difference between these footers and the old Soundware Superspikes. Looks like the same design.
Joe's is a patented technology that uses material physics based on the second Law of Thermodynamics. The ones you show are not even close. There is no adhesive superspike or any of that junk . It would be a simple a/b comparison for you to understand the difference
read the review from Sircom. It will help
It's neither. The inly thing the 2 footers have in common is that they are both black anodizedOk...Is it a spike or ball bearing under the moveable foot? How do I see the internal geometry or it?
Hi JimJoe-
A couple questions:
1. What would be the most appropriate model for a Schiiit Yggy? CS2M 1.0 or 1.5? 3 or 4? Would 3-1.5s>4-1.0s?
2. Thoughts about the CS2M with an ARC REF6SE? I thought i saw somewhere that they were not recommended.
3. Due to constraints imposed on me by my marriage, I only get to have the system on and listen to it 4-6 hours per week at the moment (I know, I know ). It seems like the "adjustment" time for the CS2M will be very, very very long and I need my 4-6 hours/week for my sanity. Comments?
Thanks,
-jim
@joelavrencikCMS
Joe-Hi Jim
The answers to your question are:
1a) Any size foot would work. 1b) 4 is always better than 3. 1c) I don't know as this question is outside my design parameters. What I mean is, my objective is to ensure a clearly audible jump in performance as the height of the foot increases when 4 feet are employed as has been our longstanding design goal.
2) You are correct. The Ref series uses an acrylic baseplate. You can put the feet on top of an acrylic surface without any loss of performance whatsoever, however you cannot put the feet under an acrylic surface. This causes the soundstage to tip up.
3) Lots of listeners share your situation. The result would be worth the wait. Having said this, the exact amount of settling time required is system and component dependent. It is usually different for most people. Perhaps, you could consider playing the system at ultra low levels at night?
I hope this helps.....
Joe
I want to correct myself!!!! I should have said Ref6 in my answer to you. I am very sorry for causing confusion........Hi Jim
Joe
That will definitely work well.Joe-
Thanks for your clear answers. I am moving in a couple of months, so will hold off trying the CS2Ms till then. Will probably start with four 1.0s under my Yggy.
-jim
Joe,That will definitely work well.
They aren't meant to be stacked. Not a good ideaJoe,
The M versions are not so new, but I expect to only start to move to them in the near future. This will leave me with a surfeit of the older versions. I am thinking that I might try stacking them, I.e, regular version under M version.
Any thoughts on this?
best wishes
aubrey
AubreyJoe,
best wishes
aubrey
