Do you find that tracking ability improves after it‘s broken in, especially for low compliance cartridges?
Makes sense. It is the suspension that needs the run in, and that does affect tracking.
Back to the OP, I started out like everyone else in my generation… with “needles.”
Moved on to cartridges from Stanton, and Pickering when I had a TT that was compatible. Got into Shure, and eventually into their top of the line tracking masterpieces. They were unbelievably expensive at over $200.
Later to Grado and Clearaudio. The Clearaudio Veritas took my breath away at its absurdly high $800 price point.
Then I discovered Ortofon and fell in love literally for decades. What a great range from top to bottom.
By 2016 I’d switched again to try a Linn badged cartridge. This was on a whim to have an all Linn kit. That did not go well, and so within less than a year. I decided to check out Lyra.
I moved up from Delos (the teaser) to Kleos (significantly better) to Etna (wow… best I’d heard on my Ekos SE arm), by 2018.
Auditions of the Atlas were great, but so was the Etna, so I stayed with the Etna until this year when I took advantage of Lyra’s trade up program. I traded my Etna for a 50% credit on a brand new Etna Lambda. It is a major upgrade over the original Etna (which is a wonderful cartridge).
Alan Taffel reviewed the Etna Lambda in issue 338 of TAS (the current issue for May/June 2023). Although I doubt that I could have written the review, I read it carefully, and agreed with every observation that he made. The Etna Lambda at $8995 has to be considered as both an outstanding sonic performer (at least on my Ekos SE arm through my ARC Ref Phono 3), and an excellent value.
It sounds great not long into the first side, but after 40 hours of play in time, it’s just incredible.
I was getting to think that my Rossini DAC might bring digital close to analog here. The Etna Lambda has changed the equation, and not in a subtle way.
