Isolation Transformer and Balanced Power versus PS Audio Regenerator
I had the PS Audio PPP, P5, and P20. The problem, for me, with all of the regenerators (including the P20) is that they add noise. If you think about it, it makes sense: the act of creating a new signal cannot be noiseless. Now, if that new noisy signal is less bad than your incoming AC power, that's fine. In my case, my wall power is not bad (~123V and ~2.5% THD). With a highly efficient horn system, I could definitely hear the noise the P20 was generating. It is also not really truly "regenerated" - it is generating based on what's being input. That's why the output depends on the input quality.
Also, none of these isolate between/among outlets. Components dump dirty AC back onto the circuit. The Power Plants do not filter that.
I switched to Shunyata Denali v2 and have been much happier.
The regenerators do not filter AC power. They do what they say they do- its regenerated.
A power supply converts the AC line to a DC Voltage which is then used to power a low distortion 60Hz oscillator whose output is applied to an amplifier which powers the output of the device. In this way noise on the AC line is not transferred to the output.
The amp uses a substantial amount of feedback so it can react to noise injected onto its output by reducing or removing it entirely.
What sort of noise did you encounter? I used the P20 at AXPONA a few years back and it worked extremely well maintaining line Voltage (always a problem at shows) and was very good at eliminating a substantial spike that randomly occurs in that venue. The speakers I was using were only 98dB but our system was very well behaved- nice and quiet.
I did not say they filter, I said that they regenerate!
The "new" AC is certainly better than the incoming AC, but some noise is still passed through.
Garbage in = Garbage out.
Paul at PS Audio is a consummate salesman. He thinks he's Steve Jobs. You cannot create perfect "clean power" when you start with noisy power - for the same reason that a component cannot clean the incoming AC perfectly.
It's an OK product and especially good if you have really bad power (voltage fluctuations and/or noise); but otherwise, there are better products available, especially for a high-end system that will amplify any noise.
Hm. This is what you wrote previously. Its basically incorrect; if not 'truly regenerated' then a filter must be involved. FWIW I tend to take things very literally and am also an engineer so these words might mean something to me they don't mean to you.
Actually you can and that technology has been around a long time.
You didn't mention what sort of noise you encountered that you attributed to the PSAudio.
I am an engineer as well.
You cannot regenerate a brand new signal. It is using the incoming AC to create an 'improved' version of it. It's just a simple fact. You have dirty power being input. Some of that noise will make its way into the output. The "Regenerator" is really just an amp.
Even PS Audio admits this - you have to search through their forum, but Ed and Paul (reluctantly) admit that the output is not noise free and is still a function of the incoming AC.
What noise - elevated background noise that would vary by time of day - a telltale sign that the "regenerator" is passing noise through.
The other problem with it is that EMI/RFI noise is passed through to the output. This is why adding 3M RFI/EMI sheets in certain areas will reduce noise. There is a huge writeup on this on the PSA Forum.
Reactions: John T
I did the same, and was happier too. I still believe power regeneration is valuable for devices that have motors, tape machines, CD players, turntables, because you get a near perfect voltage and near perfect sign wave. Had a PPP moved to Shunyata Denali V2. Two actually for all signal path electronics. Because my power amps and fieldcoil ps x4 are next to loudspeakers, the rest is on an adjacent wall.
Reactions: Zeotrope
Yes, same here.
BTW, the Field Coil PSUs really benefit from cleaner power and grounding. You probably know this already. If you think about it, the field coil is essentially in the signal path as it's half the equation of generating sound -- just like permanent magnets affect the sound.
Reactions: DetroitVinylRob
Gentlemen, the following video provides some objective measurements on the effectiveness of the PS Audio Powerplant (in this case the Powerplant 12) in taking extremely crappy and noisy AC at the input and "regenerating it" into pristine AC with perfect sinewave at the output. The bottom line is that it works.
However, the audibility of clean AC sinewave (vs dirty AC) has not been tested or verified through double-blinded random controlled testing. Therefore, the subjective system-dependent "benefits" are still open to vigorous debate and discussion. But that's what this thread is for - the more anecdotal examples, the better! :)
Reactions: Zeotrope
Exactly what I was saying. "There are power conditioners that lower noise more than the PSA AC Regenerators". That's noise. AC voltage fluctuations do get stabilized.
It depends on what you need: do you have AC voltage that is more than ~10% off the nominal 120/220? Does your voltage vary? If so, the PSA products may be better than a passive filter.
If you are after noise reduction, the PSA Regenerators are not the best on the market.
Who has compared directly in the same system, on an apples-to-apples basis, an isolation transformer and balanced power device (e.g., Equi-Tech or Torus or Furman P-2400 IT) to a PS Audio power regenerator?
What sonic differences did you hear between these two different power solutions?
What were the advantages and disadvantages of each system?
Did you notice any negative or deleterious effects on the sound from using either type of device versus plugging the system directly into the wall outlets?
I tried balanced power going into my DAC, transport, phono-pre, head-amp and into a low power amp. In each case the sound was much improved. Balanced power gave the system more air, low level articulation, more 3-D presentation and a blacker background. Definitely a nice improvement.
John
I completely agree, I have the same result with my new P20 2025.
Hello
I agree that P20 regenerate AC and for me it remove all noise due du DC offset (asymmetrical AC sine wave) and also help in the sens that my AC fluctuate from 228 to 247v (in France). So P20 remove all noise from the audio system as it use a huge toroidal transformer and output perfect 230v. I still use very good power cords at the output of P20 to power may components but no other filters. I also use AC grounding with artificial ground box. This do not remove noise but gives a naturalness to the sound especially highs.
The regenerators do not filter AC power. They do what they say they do- it's regenerated.
I'm so impressed by this PS P20 that I am now PS AUDIO dealer for these regenerators.
I tested my mono blocks on P20 and direct from the wall. My monoblocks sound much better if they are powered from P20 high current outputs, by a clear margin. If this was predicted by the amplifiers manufacturer, this proves that monoblocks of 450w@4ohm with 75A peak are easily powered by P20 as it was clear too for STEREO TIMES, STEREOPHILE, HTA and others.
Test in French
I see a lot of test about regenerators. What is interesting with regenerators, is having a pure sine AC wave at output with no distorsion and lower impedance that the mains. PS AUDIO P20 does this, very easy to see on the screen but also on my oscilloscope. Removing DC offset is mandatory for high end audio but also for more modest audio systems. Listening tests done here were easily in favor to P20 as power from the wall. A famous electronic designer told me that it was a predictive result as it is the only way to have no AC issues that could saturate transformers, and also this helps electronic power supplies to be filled easier, even if this is very less interesting than having no sine wave flats or difference (DC). That said, then if very good power cords could (should) be used after P20/P15, no conditionner or fancy AC filters should be used.
Reactions: matthias
I went via all of this including all kinds of regenerators ,conditioners , 7 balanced trafos (to isolate each component) , StromTank , p20 , Gigawatt.
They all do something good but after some time you always get to the point that they also TAKE AWAY something good.
So in my 25 years journey I tried everything and got always back to play without those.
The only clear improvement was 2 sepatate 10 AWG Oyaide solid cords directly from the main power panel.
So I would invest in that first if I was You.
Recently I contacted Karen from Transparent Audio and by her advice I tried Transparent Opus power cables and Transparent Opus Power Isolator.
I am amazed. I can say that this will be my main investment once I get back on track with some cash.
It will cost a fortune if I decide to use it for every component but this is the only solution that works wonders in my system without taking any of the good things.
Give it a try.
I would personally prefer one Transparent Opus power cable than all of those other " solutions" together.
Reactions: John T and PhP
[emphasis added] That's a matter of how well the power supplies of the re-generator are and how much feedback is applied to the amplifier within. But I take your point.
There's a company called Elgar that many years ago made excellent AC power conditioners. Their technique was to use a large isolation transformer which has windings for feedback and a power supply for an amplifier. A low distortion oscillator is synchronized to the AC line frequency and its output compared to that of the isolation transformer. An error Voltage is produced which is amplified by the amplifier and applied to the feedback windings, which also buck the transformer. In this way the output THD was quite low right up to the full current capacity of the conditioner and the AC line Voltage regulated. They are quite effective. But all of them I've seen have had to be rebuilt due to their age and they have a rather noisy fan, being built for commercial/industrial applications. They appear to have been made in the 1970s.
Reactions: NaimYourTubes
Test in French
What mono amps are you using ?
Hi Chris
all
Give it a try.
these experiments depend on your AC quality. If you have any DC offset, nothing cure appart regenerators, PS AUDIO or other brands. Of course I changed my mains 2 years ago ad do not use AC outlets. I made an "external line" with high quality power cables for PRANAWIRE connected to unfiltered power strips from OMEGA AUDIO CONCEPT. This was a surprise how they improve the sound vs using state of the art power cable from AC outlets in wall, wire with serious power cable but not outstanding. We get the same conclusion. Here the benefit of P20 is mandatory, but I never have success with isolators or line filters active or somewhat "passive". But if this TRANSPARENT OPUS PC + isolator is your reference, this is a good thing.
I will also use Ground Master AC from PRANAWIRE, which will be useful in my house.
Reactions: John T and Kris
Hi Chris
all
Where in France are you located ? A major city ?
In my experience with the PS Audio regenerators, all I've tried were the best in making a positive impact and improving the noise where the smallest detail stood out without needing to listen hard to hear them. Also, there was no bleaching of color and tone for detail which was much like turning the treble up on a receiver. Take mid-bass away and you will hear more details but at a huge loss in body weight color and tone. Bass to mid-bass supports everything reproduced above them.
Some good points made.
Various equipment does respond differently to the various filters, regenerators and isolation transformers. I have heard this with the various amps I have, as well as front end equipment.
How many people optimize their power supply to support the use of any "conditioner". That is a first step. Even PS Audio will say the unit sounds better with a good power cord.
Just to be fair, I am now a paying advertiser on whatsbestforum. And I am a rep for Torus. I have a bias and sure, I want to make money for all my time invested in figuring this stuff out. I have been at it since 2014. Really looking at what make an audio system tic when it comes to electrical power. I will be the first to tell you, don't buy a Torus or Everest or AQ5000 till you optimally set up the infrastructure of your home to support it. They are not band aids. They are purpose built devices that oddly rely on a very good electrical supply to do what they were designed to do. In the Suncoast audio interview with Caelin on the Altaire grounding box, Caelin said their listening/evaluation room has its own dedicated isolation transformer feeding it. That should tell you something.
I am ordering a Altaira signal ground soon. Our friend SCAudiophile convinced me.
When anyone has me design a new room and I am using a big wall mount, I always encourage them to have unfiltered premium circuits in the room. Just in case. Especially at the rack. I don't have near enough data and customer feedback on how the various filters perform on the front end. What I do believe is true is that most well made filters will improve upon the front end. Most filters struggle with amplifiers. Torus seems to have significantly less issues and great upside with amps when you set the electrical foundation correct to support them. But having unfiltered circuits from the panel that feeds the Torus, going to the rack and/or amp wall is not a bad idea.
I firmly believe power and room are the top 2 foundational component you need for any 2 channel stereo to reach its full potential. I use to be very suspect of filters. I know see, done right and powered properly, they are almost a necessity. There is too much noise from the home and the street.
@Atmasphere, @Kingrex: Opinions about using a PS Audio Power Plant (to regenerate ac mains) in conjunction with (in front of) a Torus rm20?
Reactions: PhP
