Did you try a cheater plug to lift the ground? You may also want to try running a ground wire from somewhere on the JOB chassis back to your preamp.
Thanks for the tips, Mep--I tried both to no avail.
By selling it of course.
Since no one else has raised this issue, maybe you have a defective amp. Did you contact the company yet to ask them for advice?
Pictured is the recently released Telos 390.5 integrated amp.
The circuit board underneath to the right looks like the same used in Job 225, and the circuit board underneath to the left is the same used in the Metis 2 preamp.
Yep, just emailed Goldmund. The problem improves somewhat, but not completely, if I unplug the interconnects running to the amp (whether or not the preamp is connected or powered up).
The manual is replete with warnings about interference from wiring and other devices, and I live in an apartment in an urban area, which might explain the problems.
Despite the hum, it sounds great.
Sounds like a ground loop problem to me.
He tried a cheater plug and that didn't work. Even with no ICs plugged into the amp from the preamp he still has hum so I'm not convinced on the ground loop theory.
Love your sense of humorLet me know when you decide to sell it. I may just order custom made power transformer to replace the 115V one.
PS. If your lil Pioneers didn't blow up, you will be fine with TADs too. Most SS preamps are DC-coupled anyway, and have virtualy no DC at the output.
Just to clarify, the hum is much reduced with no ICs plugged in at all, but it doesn't matter whether the ICs are plugged into anything on the other end. I've tried three pairs of ICs, too, just to make sure I didn't have a bad ground on one of them.
Mysterious--I'll wait to hear from Goldmund before I make any moves.
