Perhaps I should just post blanks to threads like this.
Tim
I perceive that is what you are doing, indeed!
Tim
...I rest my case. Oh and make this "all of these tests that challenged their core beliefs were flawed." They usually fail to find fault with the tests that agree with them.
Oh, and this description of an exhaustive process?
I didn't make it up. Any guesses as to what study I'm talking about? Hint: it was broadly and immediately rejected by the high-end community. And bear in mind, that's a description of what I believe it would take to possibly change a few audiophile minds, not what it would take to make a statistically valid test. That's a lot easier.
Tim
A very good point. And I want to add a comparison from my profession of professional violin playing: In the business of providing violins ("master" violins) to the aspiring young fiddler, violin dealers nowadays rarely let you take out an instrument, partly because the high value is difficult to insure for a few days (or so they say), and partly to keep control over the evaluating process:
There has been a lot of Stradivarius bashing of late, which will not confuse any true specialist: A Strad is a fantastic stile of instrument, among many other fabulous makers of comparable quality, be it old or new
But to get to know it, and being able to handle it, you usually need an extremely light hand and a free mind, which is unlikely in a "TEST" situation.
Why am I writing this: You will never hear what it (be it a violin or an audio system..) can do within a split second. I am a firm believer of extended assessments, where the results hit you, just like Tim says, without any proof ;-)
egidius
Tim,
Please give us facts - nominate and refer explicit to the tests you are addressing. Although I think that the ALL you refer are the usual very few, may be you are referring to something more recent.
Nah. They've all been argued out on internet audiophile boards to exhaustion. I see no good reason to re-live them here. It would change no one's mind.
Tim
OK. I understand that you were just addressing the old exhausted flags. Surely they will not change any one mind.
Tim
I've been wondering, what people who are so hard on Jplay think about differencies in sound quality between Mac and PC platforms?
Almost everyone that tried both agrees, that PC sounds better than Mac
Are there really no differencies, or maybe the resolution of measuring equipment used is just not good enough? Or maybe we are measuring the wrong things altogether?
A couple of points: first, I have not tried jplay, as I do not use windozs. I use a custom linux server, which is already optimized for music playback alone.
The reason that folks are skeptical about the supposed sound quality advantages of jplay is that even the developer themselves cannot even offer a single plausible reason for any improvement in the case of a well designed, asynchronous USB DAC. Perhaps jplay are just being coy, and would rather not divulge proprietary secrets, but the absurd elements of its operation which they have mentioned here is not doing them any favors: in fact, I think they could be more convincing by just claiming they use a proprietary approach.
In my experience, electrical and airborne noise from a computer music server can, and often does, affect an audio system negatively, when the serving device is located in close proximity to the system, and/or powered from the same mains supply. It is in this area where, I believe, some music player SW programs can have an advantage (and purpose built servers as well); by shutting down all operations on the server not needed for audio playback, noise levels drop, and sound quality can improve, in some systems. Windows, of course, is notorious for the amount of computer resources it uses just to be running-so if jplay minimizes CPU load, and hence power consumption and noise levels, I could accept that having a positive effect in some systems. Of course, there are probably other ways to accomplish the same thing.
I am a little bewildered by jkenny's apparent lack of knowledge on how to properly isolate a USB interface though? I thought he was much more knowledgable about this? The approach which does work, is as follows: lets consider a system using the XMOS processor for our example, USB cable comes from server, and goes to the USB receive board (inside DAC). The XMOS processor is powered form the USB bus, and grounded to the host server, this is the "dirty" side of the system. Then the I2S output of the XMOS goes through isolation chips (typically GMRs), these isolate everything including ground. On the "clean" side of the interface we have the oscillators, and a signal processing chip. The "clean" side is powered from a clean power supply of its own, and the masterclock clock is sent back to the XMOS through the isolation. The I2S signal is re-clocked by the oscillators on the clean side, removing any jitter from the XMOS output and the added jitter from the GMR isolators. This approach allows for jitter at the intrinsic level of the oscillators, and has no limitation on sample rate. This is the approach used by the best USB interfaces, both internal to DACs, and as external USB-SPDIF converters.
First off you are not fully isolating the USB receiver, are you - the USB receiver is still in contact with the PC ground & in your XMOS case driven by the noisy VBus - you really think this isolates it? I used a USB receiver that was not powered from Vbus.John: OK, so why then did you claim earlier in this thread that applying appropriate isolation to a USB receiver is difficult? I am still confused? Clearly, there is an appropriate solution, which is in common use in the better USB interfaces.
Second, care to tell me how many USB converters or DACs are configured such?
Thirdly, do you know this solves the issue or are you working on theory as you are with Jplay i.e have you tried this type of USB converter/DAC?
So if a €100 Jplay software does as good as these expensive devices with regard to noise isolation, are you complaining?1. It matters not. The noise stays on the XMOS side, and the signal is re-clocked on the output side directly by the oscillator(s). There is no ground connection between the computer/XMOS side and the output/clock/DAC side, nor any sharing of noise. Of course, one could also provide a clean supply (separate transformer or battery) if one was paranoid about it. I prefer to use an separately powered USB card on the server side, to insure clean power supply to the XMOS side.
2. Do not know, but here are a few: Ayre DACs, Wavelength Audio DACs, MSB operates with their own variation on this same theme, Berkeley Alpha USB-SPDIF, Audiobyte Hydra USB-SPDI-I2S. I suspect there are more, but those are the ones I know off of the top of my head. There are also various DIY solutions for this, as you likely well know.
Yes, the noise "issue" was the one you raised & I was speaking of. So, as I asked have you tried one of these DAcs that you have listed? What is your experience with it's isolation characteristics?3. Solves what "issue" exactly? I do not think we are dealing here with any well established issues. The only issue which I accept in this environment, is that nosie from the server may couple into the sensitive oscillators, DAC, and analog output stage. This method of isolation does solve the problem of cable borne noise, airborne RF needs to addressed separately if it is a problem.
Where is any measurement to show similar noise reduction and isolation? From the descriptions provided, Jplay is actually increasing CPU load by using short buffers. So even the theory doesn't support what you say.So if a €100 Jplay software does as good as these expensive devices with regard to noise isolation, are you complaining?
