Krell Saga
Fully recapped right? Yeah baby! The only way to go from here is UP. Congratulations Mark!
Ah Tom, you are always such a ray of sunshine on a cloudy day :p
Both pieces have been fully recapped. 56 new caps alone in the KSA-250.
But have you had a chance to listen yet :confused:
It's Saturday morning and I really don't have a lot to report yet. I'm not going to judge the Krell gear until they are broken in a good deal more. The KBL doesn't have as much gain as I'm used to in a preamp. Even with the gain switch engaged, it's still less. I guess the plus side of that is that you get to use more of the volume control range. I could never get much past 9:00 on the volume knob before without rocking the house down with my other preamps. Now I'm closer to 11:00 with the KBL. I am running balanced MIT ICs between the KBL and the KSA-250 and they are brand new as well.
I had to turn my bass controls on the subs that are built into my speakers down which isn't a big shocker given the reputation of the KSA-250. If you have never seen a KSA-250 in the flesh (or metal), pictures don't do it justice. It's a beast. A handsome beast though. And yes, it runs hot. It truly does raise the temperature of your listening room as others have reported.
The first three hours after the system was hooked back up were spent with the music server driving the system. The KSA-250 didn't really start cooking (temperature wise) until I started playing LPs and tape. Even the KBL preamp power supply runs damn hot as the KBL runs in Class A as well. If I had to use a single adjective to describe the sound now, it would be "pure." We could substitute "clean" or "transparent" and I think you would get the idea.
I played the 45 RPM version of St. John's Infirmary last night (on clear vinyl) and it sounded really good. I wish I could say it sounded as good as the 30 ips tape that belongs to Chad Kassem that Mike Spitz played for us. It was cut literally from the same cloth, but the tape is just such a stunner. The LP is damn good though. If I hadn't heard the tape, I would be really singing the praises of this LP. I could almost reach out and touch Louis Armstrong.
I played all jazz last night with the exception of Lightnin Hopkins. I was comparing the Lightnin Hopkins to the sound I heard of this LP being played at RMAF over the new Clearaudio table with the Graham tonearm and the Clearaudio Goldfinger $10K+ cartridge. I wish I could say I was getting that sound, but I'm not. Maybe if I had a Goldfinger hanging off the end of my SME 312S instead of a $1K+ Benz Glider SL I would come closer, but that is not the fault of the *new* Krell gear. Don't get me wrong here, the sound was still magnificent.
Everything I played through the system sounded very good. Cafe Blue sounded like the typical Patricia Barber sound-laid back like jazz light for a Sunday morning. I should have played some Diana Krall to see if she sounded as nasally as she sounded in all of the rooms I heard her being played in at RMAF. People love to demo with Diana Krall, and most of them shouldn't. The Benny Goodman tape that Myles turned me on to is a real stunner and it rocked the house down. Even though there is too much left/right stereo separation in this recording, the realism that was captured of the sound of the instruments is breathtaking. You feel like you could get up and stroll around the people playing the instruments on the stage they sound so real. The Krell gear notched up this realism factor.
We are off to a promising start. I obviously need to spend much more time with the Krell gear before I get the full measure of what it is doing for the overall sound of my system. I did leave the KSA-250 turned on last night which I won't be doing often. I think I can hear my power meter spinning outside.
More to come...
congrats Mark
It will even get better
Mark, It will get better,congrats.
micro-No, I don't have the VTL CD. I hope the 45 RPM version sounds killer though.
Great! Please do not forget to tell us how it sounds played loud in in your Krell. I also own the LP and it still sounds great, but my experience listening to it in the KAS250 was memorable.
Actually both happen: adaption and electrical changes.
And the better the gear, the less the colorations and the better they work with different systems. And one thing no one has ever criticized Krell about, no matter the system, about is their low end!
Mark,
As the caps settle, the gain should come up in the KBL and the KSA.
I am suprised at how many folks expect that the unit sounds good without regard to how it will sound in his system, but I suppose thats just expectation bias and all that stuff.
Some of these people have actually owned this amp Tom and they are intimately familiar with how it sounds. If there is such a thing as a universal SS amp meaning that it can drive basically any speaker known to man, this is certainly one of them.
And really, the idea that turning on the unit for a few hours a day will somehow make ti sound so much better in however many days is more about becoming aclamated to the unit than electronics changing. Yes, capacitors will bias in, and transistors will stabalize with heat, but saying it will sound even just more than a bit better over time don't wash with this audiophile. Ears adapt, not solid state.
Aside from the fact that you contradicted yourself with your second sentence, I’m not sure I understand what point you are trying to make with the above statements. Most reasonable people agree that new gear has to burn-in before the sound locks into what you can expect to hear every time you turn on your system (after it has warmed up of course). Most all of the OEMs that design and make the gear we listen to provide estimated burn-in times. The last statement you made above that “Ears adapt, not solid state” is meaningless to me because I’m not sure if you are saying SS doesn’t need any break in time or you are saying it doesn’t need any warm up time, or if you are saying both. Either way, I don’t agree with your conclusion.
Sorry, but have been around this block way too many times, and have seen others as well, but sure, happy for Mark to have a new device to play with (actually two).
You may have been around the block too many times, but you’re still carrying your Hafler gear that you have been toting for many years so nothing is changing in your system. There is nothing to burn in. If you tell me that you always turn your preamp and power amps off after you finish listening and when you power it up the next time the sound never changes as your gear warms up, good for you. And yes, Krell did tell me to expect changes to the sound after the capacitors have fully broken in.
Interesting does Krall sound that way live? I play her quite a bit and have never found that trait in her voice.
Roger-I haven't played any Diana Krall yet so I don't know for sure, but I doubt it does. It didn't before at my house, but I sure heard a lot of rooms at RMAF that made her sound nasally.
Bad digital :(
I have often thought Diana Krall has a smokey quality at times much like Julie London. Bad digital hash I guess could be the reason,you would think that most exhibitors at shows could spot that a mile a way.
btw I switched coupling caps on my digital rig.....it came with Wima MkP's that sound edgy. I switched to Mundorfs.....smooth as silk.
We need to think back about what Gary said. The systems normally sound best on the last day of the show. Why? Because everything has normally been left on and the system has spent more time playing music. I heard a huge difference in the sound of Gary's room from Thursday night to Friday morning. And Tom, that goes against your "ears acclimating" theory. When you go from room to room to room, your ears are constantly hearing a different sound from the vastly different systems. Gary's system didn't sound much better on Friday because my ears had acclimated to the sound of it. Hopefully Gary will chime in here with his thoughts.
As for smokey voices, I would put Patrica Barber in that catagory before I would put Diana Krall in it.
Yes she does have a nasally style. I've watched her live but you can see it better in her concert DVD closeups.
Vastly different systems....all reproducing the live event....differently...no, thats vastly different recordings, and speakers mostly. They should all tend to sound the same with the same recording if they were really trying to capture what is on the recording....but then I blame the stereo concept more than the folks trying ot make a living in audio reproduction given what they have for a source.
to continue:
So, Mark, are you telling me that world class equipment,
audibly changes its sound, for the better, if it is played hard for 8 hours a day,
rested at idle overnight, then played hard again for 8 hours,
then rested overnight and on the third day of playing hard,
you can remember back from the previous two days and compare the sound and it is now even better?
Just when is it "the right time" to evaluate a piece of equipment or a system of equipment then? The 4 or 5th day or the 5th hour after playing full tilt or what....is that weird or not?
How do you know when your gear is at the right "conditioning" point (or your entire system) so that you can "hear" this obvious audio difference?
Your speakers will be worse after playing for a while, technically, as they get hot (even pro speakers). That would be worse sounding technically.
I think it is mostly in our heads as we are more relaxed on the third day of listening, or even the second day.
But if anyone has some ideas would be glad to consider them.
I am not denying that gear changes with temperature, but world class gear should be subtle, and essentially inaudible to changes.
Tom
Tom-I promise you that I'm not trying to tell you anything. I cried "Uncle" with you awhile ago. Believe what you want to believe and try to be happy.
