It's been hooked up for 2 hours now. I played a record first hour in. It sounds better fresh out of the box than the LP2.1 Deluxe did. I know this thing is going to make beautiful music from my records.Christian...well...how's the LP1 Sig fresh outa the box?
Congrats! I'm using an LP2 deluxe with NOS WE tubes. Ypsilon MC16 into MM input. I'm in heaven, so quiet, scary dynamics(listened to a telarc Fennell test pressing last night stunning[and i'm a rock guy]). One critical factor for me was the rectifier tube, not sure the power supply situation with the LP1( I have 6X4's), but definitely experiment with the rectifiers. The LP2 goes warm and fuzzy(euphonic but dynamic and extended) with a 50's Mullard,and fast and sharp with 60's yellow box Sylvania. I found a 50's tungsol to be the happy medium. Enjoy, for most of my carts Lyra Kleos sl, Koetsu RSP, Benz Ruby H I preferred them into a SUT(MC16/EARMC4) then into the MM input. The 1:10 jensons are good in the lp2, probably better SUT's in the lp1 sig , my point is experiment, especially with rectifiers! I find it needs a good hour to warm, then an hour of play to reach its peak, at 3-5k hours per tube I don't stress.
Jeff
Jeff
Where did you guys ever find 417As????????????
Does anyone keep their LP2.1 on 24/7 or turn it on just when listening?
I just turn my LP2.1 on for listening. I'm always concerned with the risk of fire and shorts with tube gear and I have 6,000 vinyl records to be converned with.
The reality is that Vlad recommends leaving his products on as do many tube gurus as the point to be made is that tube failures typically occur when a component is turned on or off
My original pair of ML2 on 24/7 unless I'm away for the past 18 years, the same for all my Lamm gear always left on except periods that I'm not around. According to Vladimir the parts get stressed most during turn on, his equipment is bulletproof just turn on and enjoy!
david
I have to agree with this but when I leave mine on as you do my electric bills go up enormously. Cost of electricity I guess is much higher in California.
David, I thought you leave your ML 3's off unless you are using them
