Lampizator 11 or 11p conversion
Geerock
28
21
68
Hi
I want to get my Golden Gate upgraded to the engine 11 or 11p but I'm having trouble deciding which one. The 11 is about a 2k dollar cost and the 11p 4k cost. The unit already has the upgraded caps and JLS card so it's basically just the engine and associated parts and adjustments. Will I be leaving a lot on the table by getting the 11? I know everyone has said going to the 11 from the 53 is a no brainer, but I don't see any info on the upgrade from 11 to 11p.
Anyone?
Thanks.
I did the upgrade of my balanced GG1 to 11P, new VC and USB card. Its amazing except I am not sold on USB. S/PDIF sounds better still. They moved the power button to the bottom and I couldn't find it for a long time.
I suspect you will neither sleep well or pay the shipping again if you don't upgrade to 11P now.
Thanks for the reply. I'm already an I²s guy and had that put into the GG a few years back. It certainly is a better sounding connection than USB in my system.
Reactions: RikkiPoo
I assume the "engine" is an AKN chipset yes?
I am on a GG1 with DAC board 5942 and Amanero USB + clock upgrade. I am using it to play DSD256x via USB only (using HQPlayer). I am not interested in investing in / upgrading the PCM audio path / route, since I do not use it. Does the Engine 11(p) upgrade have any major positive effect for DSD only playback (via USB)?
@Geerock: I am unfamiliar with feeding a Lampizator GG with an I2S signal? Mine only chews USB and SPDIF (AES, cinch, BNC)...
I have a fair bit of DSD and the sound is richer and sweeter than red book or hirez but I have not made a playlist of my DSD files so I mostly listen to qobuz. Unfortunately I did not spend time listening to DSD specifically after the upgrade so I can’t say what the difference is with complete confidence. I will say my impression is that yes the DSD improved after the upgrade with a lower noise floor. Part of that may be the new VC and not the Engine 11p.
