I am looking through the thread for tubes to try. Could let me know what tubes are this? Are they 6N1P-E?
Which tubes?If anyone wants to experiment with tubes in the Posseidon or Pacific we discovered a new 6N1P substitution tube. Game changerUltra linear, ultra low noise and so much fun to listen.
I haven't rolled tubes. I've lived with my Poseidon for 8 or 9 months. You should listen to it for a while prior to changing tubes. It is a great sounding DAC and pre-amp with OEM tubes. I don't have a SOTA system but it's high end.I am looking through the thread for tubes to try. Could let me know what tubes are this? Are they 6N1P-E?
I have a bunch of Bendix tubes which are unobtainium if anyone is interested. They are mintI recently heard my Poseidon with Bendix 5992 tubes with a Mullard GZ34 fat base rectifyer and the combination was easily the best I'd heard. The Bendix tubes took some of the harshness in the upper trebble off the GEC 6J5 tubes I've been using whilst maintaining the leading edge dynamics and overall musical coherence, whilst the Mullard recitfyer added a lot of useful separation and imaging to the sound.
Sadly, it seems that Bendix 5992s are something of a holy Grail tube.
so Ive been corrected...my Bendix 6900 are signal and not output tubes . Having said that when the H1 was released it was Lukasz favoriteI have a bunch of Bendix tubes which are unobtainium if anyone is interested. They are mint
What harshness are you speaking of? I don't hear harshness in my system.In my Neptune (which is same tube types as Poseidon), I am using JJ 6V6S instead of 6J5 and it is exactly removing the harshness. JJs are new production, inexpensive and excellent sounding.
6N6P have been replaced by E288CC (no adapter needed) with great results as well.
I am also tempted to try new production 6N30P from EH or Sovtek. Has anyone tried these already?
Regarding the harshness, I was referring to stock 6J5 which are good but a bit "crude" sounding tubes. When replaced by 6V6S from JJ Neptune gets even more natural timbre and a bit bigger soundstage.What harshness are you speaking of? I don't hear harshness in my system.
I read this on-line about using E288CC tubes instead of 6DJ8/6222/E88CC tubes.
"The E288CC / 8223 are absolute top sounding special quality tubes. They are not exactly the same as the E88CC / 6922. They require a little more heater current (0.475A against 0.3A) which the amps power supply has to deliver.
Also they have slightly different amplification and plate impedance, but this is not problem in common E88CC circuits."
On Neptune page in Lampizator site it says:Anyone try EL34/6CA7/KT88/TK77/6550 type of tubes in place of 6V6, provided that they are supported?
now running directly into Almost certainly (but not conclusively) what you're hearing was the result of not playing it through the preamp. That collapse of soundstage is precisely what I would have predicted would be any potential downside to removing a good preamp.
I know that Lampi make a big thing about the preamp stage in the Poseidon but I just don't agree that it's better than 95% of preamps out there. I suspect, but don't know for sure, that a pre will almost always improve things.
Did you not even try it with your pre in place?
Any pointers for the source to acquire the JJ 6V6S. Same question for the RCA 6Y6G tube.In my Neptune (which is same tube types as Poseidon), I am using JJ 6V6S instead of 6J5 and it is exactly removing the harshness. JJs are new production, inexpensive and excellent sounding.
