I thought you were already running TAS. Do you mean XMDS?I'm so ready for TAS !
That would be the Extreme thread.
Have an espresso bud.
But I concur, either of those would be great. Maybe next week.
Ive been running only TAS for the past 2 years. XDMS is on the radarI'm so ready for TAS !
Yes, XDMS. I stand corrected.Ive been running only TAS for the past 2 years. XDMS is on the radar
lol somthing like that meant XDMSMaybe he had too many espressos!
Tuckia your using a laptop , do you get porn pop ups when looking for musicYes, XDMS. I stand corrected.
it’s easy to remember Roon because it sounds like Ruined.
Is that what that noise is? I thought a tube was starting to failTuckia your using a laptop , do you get porn pop ups when looking for music
I've been following all that has been written here about the Lampizator Horizon. Been a solid state guy my entire life, back to Phase Linear, Empire TT, Revox A77 (Swiss Made) days. I'm intimidated by the tubes! But also intrigued. Maybe its the tube rolling aspect? I'm using a DV2 with Mephisto/Pandora, JA Pearl 20/20's, Taiko soon to come. Don't think I can get away from Gryphon. System is dialed in. I'm a Blues, Jazz, Classical guy, so the Tube aspect makes that more appealing. If anyone has some advice, input, wisdom, to someone that is thinking Horizon, please share your thoughts with this conundrum...John
About ten years or more for the output tubes. About 3-4 years for a rectifier.What is the longevity of the stock tubes? I average 5-6 hours a day, some days longer. John
Not to argue but where did you access these figures. life span of tubes is not linear for one. And next smaller less powerful tubes can last longer sound wise.About ten years or more for the output tubes. About 3-4 years for a rectifier.
Powered for 16 hr days or so. Or leave on full time for less power cycles, although this may lessen rectifier duration some.
Of course your questions and comments are pertinent and not the first time this general question has been asked. I see that you just want to go a little further with it. Admittedly, I gave a brief, concise answer to a brief concise question. A 10 cent answer.Not to argue but where did you access these figures. life span of tubes is not linear for one. And next smaller less powerful tubes can last longer sound wise.
i find output tubes sound good at less then half of what makers claim.
tube life is simply not in line with sound life.
if you take any tube about half way of what ever life is listed and compare to new burned in tubes and post back lol.
now having said this a lampi is not even close to normal use of any given tube except for a recti tube
it’s why yoda in the past keep output tubes on in standby
I do agree off on cycles is in some ways worse then leaving on. if the output tubes play no music only the heater is being used.
keep in mind as electrons beam back and forth on the plates they do decay increasing conductive resistance. I think it’s called moes or something like this.
Excellent post, Tuckia, thank you!Of course your questions and comments are pertinent and not the first time this general question has been asked. I see that you just want to go a little further with it. Admittedly, I gave a brief, concise answer to a brief concise question. A 10 cent answer.
Considering the primary audience, John T, I think I know what he is looking for as I‘ve communicated with him privately already. He’s considering a Lampizator and wondering if the tubes are a PITA and constant cost drain. Just a basic consideration before making a commitment of magnitude.
So what is my reply based on.
1. User comments.
2. Lukasz‘ comments in these forums.
3. The Horizon manual.
4. My experience.
I believe the first DHT offering was the Big 7, which I don’t think has been around 10 years yet. Really doubt there is any test data from users who have had the same tubes in continuous use for that long. If anyone has test information to share, please do. My experience is with the GG models and Pacific. Can’t say anything about the pentodes.
I acquired my RKPX25 output tubes over four years ago. They have been my primary go to tubes and estimate them at 8000 hrs. They often see 16 hr. days. Rarely leaving them on full time. By my ears they are very strong yet. They run very cool at 105F on the top. About 1000 hrs ago I did a direct compare with a new pair of RK PX25. I couldn’t hear a difference.
My RK 5u4g rectifier likewise was my workhorse for 3.5 years, acquired at the same time as the RK PX25. I replaced it with another new RK 5u4g after over 5000 hrs. Back to back there was just a subtle softening of the sound with the older tube. Usable but down a little. These tubes run about 155F on top. Much hotter.
I’ve never lost a tube to failure in my GG, GG2, or Pacific.
So it‘s a quick answer devoid of perfection, comparative, and anecdotal, but suitable for the intended purpose I believe.
How will the Horizon perform? IDK but I suppose the designer has an idea based on theory and experience. Give the manual a read.
John
if you have read this thread I am not a tube roller I used the tubes that came with the Horizon, I used a set of tubes that Lukas early announced were his favorite. I then made two purchases based on a Lukasz recommendation and another by Golum. Since then I have no desires to roll. I’m sure there are better but this tube set lights up my ears and yes in the Horizon manual Lukasz strongly encourages the Horizon be left on and one should get 10000 hours of tube life
John. There is no need to tube roll but I think it’s always good idea to have a back up set of tubes. If they are rare now they won’t cist less later and yiu might not even find them
Will you settle before or after you need all new tube socketsThere is no "need" to tube roll but it is like any other system change. If you try different tubes one may find something that they like more. Said another way, I would try different combinations of tubes before I would try different cables or other tweaks.
We all have our tolerance for tube rolling. You found a nice combination, different than the stock tubes, early on. I have tried 4 different power tubes, 6 different signal tubes a 2 different rectifiers. One of these days I will settle on a set.
I
