Turn off...might hot swap rectifier....but honestly i turn it off always - safe is safeCan you hotswap on this DAC or should you turn off at back first?
They should last a very very long time in this DAC. As far as I know, it's just a tube buffer design with the Lampi DACs, so should last much longer than say in a tube amp.Thanks. How do you know when to replace tubes? Seems like with COVID I have happily put more hours on these tubes than expectedassume rectifiers go first? Anyone have estimates of lifetime of the rectifiers and output tubes?
You can hot-swap rectifiers without the slighest risk.I always turn it off, let it cool down for 15 min or so, then swap the tubes. I think its an overkill, but just gives me peace of mind.
I used to hot swap all the tubes in my Lampi DACs before but I do that now only with the recti as it is completely harmless and safe.I can fully understand the motivation behind the hot-swapping. A need to hear the change of tone right away makes sense. I have a friend who performed hot-swapping on Pacific a few times and never experienced any problems. However, since I am overcautious, I would not want to take a chance.
That might not be the case for 8 pin recti, it usually take more effort to extract, that jerking motion when leaving the socket is as good as a bang. I paid my tuition fees. Never hot swap again.You can hot-swap rectifiers without the slighest risk.
If you don't bang the hot tubes while changing, you really don't need to let all cool down.
#wiggle, wiggle, round and round#That might not be the case for 8 pin recti, it usually take more effort to extract, that jerking motion when leaving the socket is as good as a bang. I paid my tuition fees.
So wiggle , don’t yank?#wiggle, wiggle, round and round#
All a matter of routine but I understand your fear![]()
I remove hard sticking tubes with a round wiggling motion.So wiggle , don’t yank?
Do you really want Deoxit inside the tube sockets? Deoxit is good for cleaning, but it might be advisable to wipe off the Deoxit with isopropyl alcohol (IPA) before inserting the tubes. I know a guy who messed up his tube amp by using Deoxit as a lube.Serious advice - use Deoxit spray to clean tube pins and beside that they get lubed which massively makes rolling easier and saves sockets on top![]()
