Bottom of the adaptorA portion of it in the pic (in the foreground) looks as though it has a white part of the base...I guess just the reflection...
Ian, I would put the rs1003 in the left bank and the p17C in the right bank if you're running SEA portion of it in the pic (in the foreground) looks as though it has a white part of the base...I guess just the reflection...
I thought the same thing unless he wants to tame things down with the RS1003?Ian, I would put the rs1003 in the left bank and the p17C in the right bank if you're running SE
John, I would have advised what Ian has now for your rs1003 but you are running balancedIan, I would put the rs1003 in the left bank and the p17C in the right bank if you're running SE
That might give you even more gain control? But it sounds as though got that sorted out..10% of the SRS551 might be a nice mix?I have TS KT170 in my right bank and SRS551 in the left bank. I tried OS1 in the right bank and thought it to be too soft. What I haven't done is use the OS1 in the left bank and the SRS 551 or KT170 in the right bank
I m running xlr out so agree with your thoughts with rs1003 in the right bank for the xlrIan, I would put the rs1003 in the left bank and the p17C in the right bank if you're running SE
There are quite a few 2504s i have found out there , all i will say is....valvo is good but we had our blinders onView attachment 116299
Today is the unofficial tube porn day. First Ian’s cheap WE tubes, now my new mesh Valvo G2504. Just received today.
I thought you were a big SRS551/RS100 guy? Why do I see those beautiful SRF P17c's in the pentode slots instead?Lust consummated....
You can only use a pair of the rs1003, it's very worthwhile to blend the sound using another tube in the other bank like I have always saidI thought you were a big SRS551/RS100 guy? Why do I see those beautiful SRF P17c's in the pentode slots instead?![]()
Im sure it's great Ian but I feel there is something to be said for those big globe and umbrella shaped rectifiers.It's the blackest mesh plate I have ever seen
If you have seen a rs242 black plate you know what I mean.
And a very very fine mesh that from arms length looks like a solid plate. You see the mesh only when up close
Most definatelyIm sure it's great Ian but I feel there is something to be said for those big globe and umbrella shaped rectifiers.
I also tried blending with the RS1003. I attempted to explain this to SW, perhaps I didn't make it very clear. I found the RS1003 were too much. I used, OS1, KT88, KT170, in the opposite bank, to no avail. I was also using the E83F (double). Ian are you using a preamp and turning the gain down to 50 on the H? If so the gain must be quite hot on your pre? I think I read where you did some modification in your pre? Maybe its the neutrality of the Mephisto? If I turn the gain down to 62/61 it just doesn't work, diminished returns...You can only use a pair of the rs1003, it's very worthwhile to blend the sound using another tube in the other bank like I have always said
If this doesn't bring tears to your eyes I don' t know what will. I highly recommend reading the whole story of this young lady. It places difficulties into perspective...an introduction to Emma Kok
what an amazing voice in a 15 yr old. i wished i was there . it's on tidal but just doesnt sound as good as the youtube. cant wait for her first album!
There're advantages IMO to running the Horizon SEI also tried blending with the RS1003. I attempted to explain this to SW, perhaps I didn't make it very clear. I found the RS1003 were too much. I used, OS1, KT88, KT170, in the opposite bank, to no avail. I was also using the E83F (double). Ian are you using a preamp and turning the gain down to 50 on the H? If so the gain must be quite hot on your pre? I think I read where you did some modification in your pre? Maybe its the neutrality of the Mephisto? If I turn the gain down to 62/61 it just doesn't work, diminished returns...
You can save a losts of moneyThere're advantages IMO to running the Horizon SE
