as cousin Eddy said in Christmas Vacation, "it is the gift that keeps giving the whole year"......The most abused component(s) ever are Lampi DACs - actually hats down how they survive all this rolling and keep performing/working..
Did you compare the super adapters sonically against simple ebay ones? Or just visually?Just to report my own experience with the TP adapters.
I was fortunate to be able to use them for both CG3 and e83f tubes
Absolutely Amazing is my only way to sum it up.
Beautifully made but the sonics!!!
Now the Tungsram e83f trounced my Mullard ECC32’s
I fully concur with Steve and Fred’s experience with the TP adapters
Great job Lazsio![]()
Simple eBay ones are not worth spending the money onDid you compare the super adapters sonically against simple ebay ones? Or just visually?
they even sound better when the adapter is groundedSimple eBay ones are not worth spending the money on
TP are in a different league compared to the eBay ones both mid range and sound stage
Steve ,they even sound better when the adapter is grounded
Thank you!@Kuro-rin, Hi and welcome to the forum. The main European mercury rectifier I am aware of is the AX50. I haven’t tried it but it is similar to the 83, albeit 4 volt / 3.75a. From what I read, it has strong dynamics but I personally have some trepidation about having mecury in a family room should the tube suffer a breakage.
The 83 is very well known for its sonic qualities but indeed due to mercury i have too ruled it out from my room. it will be hard to remove if one breaks and contaminates the listening space.Thank you!
AX50 is in my list. Soon I´ll try it and I can report, unluckily not in a DAC.
I understand that mercury has not the best reputation about safety, but audiophiles are usually brave and always a bit stupid![]()
Very appreciated if somebody can compares between european solid plate, mesh and mercury rectifiers.
Very interesting what you say. I have an opinion just no experience yet with these european valves.
I understand.The 83 is very well known for its sonic qualities but indeed due to mercury i have too ruled it out from my room. it will be hard to remove if one breaks and contaminates the listening space.
Hi Plasmod,Microceremic sphere damping. Took quite a bit to get them in there but the whole base is filled with it. Once dry will get the exterior coat on for the innards. Srs adaptor heaven
I so be interestedHm i overplayed a bit on the number of Siemens c3gS quads so if anyone is interested ping me. They are matched with measurement protocol per each tube in the quad.
Will write my finding on these a tad later...View attachment 117672
