Which rectifiers do you think match well and which move the sound towards lush?
No idea. Just try your most lush recti or add lushness elsewhere, like cable or amp or something
According to Lukasz Fikus:Anybody have any idea how many hours an KR 242 lasts? Or an RK KR 242?
I think this is a bit of a myth.Lampi does not run valves the way amplifiers or pre amps do, so all these will last forever.. Many years
What's the point of driving F1 car if the throttle is not pushed 100%For those using 242s in the Pacific without a volume control do you have your gain set to low or high?
Give it a try at leastLOL. I was wondering if playing at low gain which would allow my preamp to be turned up some would be beneficial.
Joke aside - very well might be the case.LOL. I was wondering if playing at low gain which would allow my preamp to be turned up some would be beneficial.
One does have to acknowledge a number of life problems that have plagued Kron tubes. I've had 4 RK 300B's die on me, and one RK 5u4g, all with well less than one year of use. Now, Lampi did graciously replace them on warranty, but it leaves me uneasy about the robustness of all of the Kron tubes (of which I have several now). I'd say my batting average is ~60% dying too soon!Lampi does not run valves the way amplifiers or pre amps do, so all these will last forever.. Many years
All filament issue related I suspect.One does have to acknowledge a number of life problems that have plagued Kron tubes. I've had 4 RK 300B's die on me, and one RK 5u4g, all with well less than one year of use. Now, Lampi did graciously replace them on warranty, but it leaves me uneasy about the robustness of all of the Kron tubes (of which I have several now). I'd say my batting average is ~60% dying too soon!
Yeah, somewhat different, but the Kron tubes seem to carry much higher risks of going bad than I have experienced with a whole lot of other tubes over 30 years of "tubing". Other than the 30 hour life on that PX-25, my other ones died after ~ 1,000 hours - - very disappointing for such premium and expensive tubes. I think this is relevant in evaluating the RK 242's (of which I have a pair that have lasted about 200 hours - - just not working in my system now).We are talking different things. One is how long do they last due to the burn in the Lampi, the other is how long do they last due to the fact that the tube can be defective. If the tube is bad, it will die pretty fast, so if it has lived a while you will be fine. the dac itself is gentle on it.
This is NOT my experience with KR tubes.Yeah, somewhat different, but the Kron tubes seem to carry much higher risks of going bad than I have experienced with a whole lot of other tubes over 30 years of "tubing". Other than the 30 hour life on that PX-25, my other ones died after ~ 1,000 hours - - very disappointing for such premium and expensive tubes. I think this is relevant in evaluating the RK 242's (of which I have a pair that have lasted about 200 hours - - just not working in my system now).
Mine is 45 EML Globe even though we are talking RKThis is NOT my experience with KR tubes.
I and a lot of friends of mine have a BIG LOT of KR tubes and not one single defect so far.
I heard that the early RK 300Bs had some problems but after this exact type is not my favorite KR type, I haven't followed up if newer versions are less prone to defects now.
My favorite KR tubes are PX25 (RK and globe) and 242 (RK and regular) and 5u4g (RK and anniversary) and none failed on me
They look way different - 10v, 3.2amp for the WE242sGeneric tube question.
Is the KR 242 tube the same as the WE 242A or 242C or are they all different tubes (electrically). I can’t find the answer by searching for tube data on these tubes.
