Nice read on cryo blah blah: https://www.effectrode.com/knowledge-base/cryogenic-treatment-of-tubes-an-engineers-perspective/
Are there any US tube vendors that sell KR 242s?
Right now my only option seems to be best300b.
I'm looking to offload my KR 242s. PM me if interested.
Yes, I did. I also got a U52 and WE 422a. Everything warming in, and I've been traveling, so no verdict so far. How are the Psvane Acme and Elrog 274Bs treating you thus far?Did you get those ones?
What are you moving to, the new recti with the PX25?
Just installed the Marconi U50 rectifier. It's wonderful! Thanks Adamaley for the recommendation.
Back to listening...
I have had the KR PX25 RKs for a while now and I'm very happy with them. Unfortunately, the 242s overdrive my amp even though my new preamp ameliorated a little bit of the distortion I was experiencing (RE: Your PM, which I've been meaning to respond to). The PX25 also plays well with the complement of tubes I have available for my amplifier, which uses 805s, 300Bs, 6SN7s, and a 6SL7. If the 242s didn't overdrive my amp, I would have kept them in addition to the PX25s. IMO, they are equally as good, but different enough to have both. Since I've been on a rectifier binge recently, letting them go is financially wise.
Gee you’re in a recti spree these daysYes, I did. I also got a U52 and WE 422a. Everything warming in, and I've been traveling, so no verdict so far. How are the Psvane Acme and Elrog 274Bs treating you thus far?
Yes it does. It's very low gain, and it gives sufficient play for balancing the Lampi GG VC and its own VC to achieve optimal sound in my system with the 242s. Infinitely more songs became listenable and distorted less compared to going direct to the amp or using any other preamp. However, this didn't apply to all songs, hence the PX25s.Ok, so the pre works with them?
Ah so you are one of the guys having Misho amplificationNot to mention, the Misho preamp does everything else better than any other preamp I've tried.
On the GG1.9 with the two position switch, I used the high voltage (300b) setting for the PX25.Which tube switch setting do I use for PX25s, high heater (300B) or low heater (45)?
