Lampizator Valve / Tube Rolling Review Thread
You have the GG2 with the 5 Position Rotary Switch, right?
Then the 101d is the correct Setting, according to LF.
Does this picture mean that I should be using the 101D setting on my Big 7 MKII for PX25s? I thought people were using the 300B with them.
The Big 7 only has 2 positions. Maybe that's why the high heater setting is ok for the PX25s.
Reactions: christoph
When I had my GG1.9, I used the high voltage position for the PX25.
IIrc on my GG the high voltage position was 101d/300b and the low voltage position was 45/242/PX4.
What I am very certain is that I used the low voltage position for the 242 and the high voltage for the PX25 because I mostly only changed between those two tubes (242 and PX25).
Reactions: dminches
I have the rotary switch. The tubes glow brighter, when I put it to the 300b setting. It won’t damage them?
On the GG1.9 with the two position switch, I used the high voltage (300b) setting for the PX25.
On the Pacific with the 5 position rotary switch, I use the 101d position for the PX25.
The 2 position switch on many GG are configured accordingly for 242 (position one) and PX25 (with 101D - in position two).
242 has 4.0-4.5V filament voltage and approx. 0.65A filament current.
PX25 has 4V filament voltage, but approx. 1.8-2.0A filament current.
Can a 6A3 be used in a Big 7 / GG without an adapter?
Yeah it is UX4 base. No issues
I have been using Tung-Sol 6A3 for years. A real KR/EML house sound antidote. Quite different to either.
Just tested mine and they are quite healthy. Not brilliant but pretty good.
Thanks. I wasn't sure since it is a 6 volt tube.
I decided to pull the PX25s out and re-listen to my WE 275As. It has been a while since I had them in.
The comparison to the PX25s is interesting. The 275As are a big lighter in the bass and there is a little congestion in the mids but overall I feel it has a more organic, natural sound. The PX25s are very detailed and the bass is unbeatable but sometimes they are a tad too much “in your face.”
PX25 and PX4 have slightly rough.mid range. It makes for an exciting sound. But if you want a much smoother mid range experience then there's nothing I have heard that beats EML 45 Globe Mesh.
EML 45 may not have the best bass but that depends on your preamp. I have a tube and solid state preamp, and with the solid state Luxman for some reason 45 GM has very acceptable bass. I was seriously surprised when I got the Luxman how well 45 GM gets on with it.
Reactions: sujay
Put it on high heater. It's fine. Compared to KR and EML tubes the Tung Sol 6A3 doesn't sound anywhere near as 'hi-fi' or high performance if you like. But it has great tone and is fab for rock I think.
Reactions: dminches
The mid range with the PX25 is definitely “exciting!”
The mid with the WE 275A is calm as compared to the PX25.
What a joy to be able to get all these different sounds.
I am listening to it now. Once it is warmed up I will roll through my playlist.
Guys maybe a nice/usable link:
http://www.vt52.com/data_dht
I was thinking about VT25/10y with thoriated tungsten but seems like it won’t fly...
The mids with the 6A3 are very nice. Plus, there is no lack of bass. I am pleasantly surprised how much I am enjoying these.
Which ones do you have?
@Golum. Sylvania VT-52 just doesn't work well in my DAC after it was changed to use 5U4G with the active triode doobery. I used to listen to it a lot with 6X5. There was nothing about it I could ever say was really good it was just easy to listen to. That counts for a lot.
Reactions: Golum
They are a pair of Sylvania 6A3s. I can post a picture if you want.
I also have a pair of Sylvania 6B4Gs and the appropriate adapter.
I don't know how similar they will be to the Tung Sol but yeah I get plenty of good bass with 6A3. Its quite spacious in terms of sound stage and definitely easier on the ear mid range than KR house sound.
The pair I have have identical output. The only pair of triodes I have that measure the same for each valve.
Reactions: dminches
That's exactly how I would describe them. And I agree they are perfect for rock.
I am mostly and analog guy (reels and LPs) so this sound is right up my alley.
In my PAC I use PX25 in 101D heater position, conforming to Lukasz recommendation.
Never tried 300 B position with PX 25 though .
If I remember well in my heavily modded B7 I used PX 4 in 300 B heater position. 242 valve had too much gain in my setup with B7 , swapped then to PX 4.
Never tried 242 with PAC.
What mods did you have on your B7?
The main was R2R engin, then reduction of gain for PCM , Duelund Cast Pio capacitors, I had also black acrylic top plate and acrylic sides , finally the newest Amanero board, but it was already 2-3 years ago. It’s possible that some options are standard now.
