I use the same light. It's behind my HRS rack on top of 3 of the Nordost Odin wooden boxes. And I know you have some of those.
Lol...plenty of those boxes to stack...great idea !
HI Christian,Those lamps just aren't tall enough for some of my racks with the TT's on top. I need a lamp to clip on the top shelf, hence my choice. I like the looks of those lights...wish I could use them.
HI Christian,
Koncept make these to attach to a rack or wall. Just go to their web page & do a search.
I have mine attached to my SRA rack with no problem.
My others are floor standers like Mike's with wood blocks I made for stability on my carpet.
Hi Mike,
Ditto on the Koncept Lamps / i-towers, 1 one for the TT (red), 2 for the tape decks, (black floor standers ), & one for the chair.
Best lamps I have come across.View attachment 20037
Click on this link Christian, you know you want to.
http://www.porsche-design.com/en/Products/Home/Lamps/Pan-Desk-Lamp.html
Thanks guys for the I-Tower rec. It is tall enough for my TT. Best light ever !
http://www.amazon.com/Littlite-L-18-LED-inches-Gooseneck-Three-Way/dp/B0002RDL6G
Littlite with the optional shelf clamp.
Just went LittLite with weighted base. Seems like the standard in pro audio and MiUSA. My rack is too thick for a clamp
If this doesnt work, will entertain the pricier Koncept floor versions.
The light model is the Natalie made/designed by Jonathan Y. Plugged into one of my general purpose AC receptacles, rather than into my dedicated lines, the lamp emits no noise whatsoever. Nothing but light and that is in a pleasant warm white hue. I'd hazard a guess that the LED color temperature would be in the vicinity of 2700K. While this lamp doesn't sport industrial design quite as sexy as the Koncept lamps some of you are using and it's durability is unproven, its height and bi-directional illumination are really great.The illumination from the vertical part on the side is pretty cool.
What is the brand and model of this lamp?
Does it emit any buzz or hum?
I have the same goose neck light but with a weighted metal base. It’s LED but has a warm glow, not a harsh light, about 2700K temp..
