Lamps For Turntables
Asamel
578
1
263
Philly
This may be a dumb question but what lamps do people use to light their tt? The one that in the Yarlung thread looks interesting.
Bill Hart
2,684
174
1,150
Not an entirely practical suggestion, but I like 'found' objects. I've been using an antique brass surgeon's lamp from an old ship; it has a strange green cast (some kind of primitive filter) which unlike super bright modern lights, enables you to see much on the surface of the record. There are obviously more practical alternatives, but I had this rewired, and cleaned up, and it looks pretty great:http://[URL=http://s1293.photobucket.com/user/Whart1/media/imagejpg1_zps0658b5b9.jpg.html] [/URL]
rockitman
7,097
414
1,210
Northern NY
Christian, I just received one of these from Amazon. Thanks!
Any specific use for the red light dial position? or you just use it at the white light position?
I use the white when I want to see something, red for the mood effect while listening.
Mike Lavigne
Apr 25, 2010
12,601
11,693
4,410
I have three i-Tower LED floor lamps. used them for 6 years.
it is the perfect tt lamp.
solid base, very lightweight and flexible on top. so never a concern that the lamp could fall on the arm/platter. uses 5-10 watts, last 30,000 hours.
comes in black, grey or silver. choose 'warm' or 'white' light. has a 2 button dim/brighten switch.
tiny profile so looks great and works in any décor.
if you have a thick carpet then get a barbell weight to solidify the base (how I use mine)
could not recommend more highly.
marty
4,208
2,520
United States
I use a Littlelight LW-18 LED on the turntable and one for my gear closet as well. There are dual LEDs in the gooseneck head; one is red, the other is white. The gain knob automatically switches between them, being complete red at minimum level, and completely white at high level with a blend in between. Since I prefer low luminance, red is the frequency of choice because it does not bleach your photoreceptors, thus you can preserve your dark adapted state. This is useful for theater, studio, cockpit lighting and perfect for an audiophile man-cave. The cheapest I've found one is here: www.performanceaudio.com
Mike, I liked yours so much, I am considering getting one for my listening seat. Although I also have the Lutron remote system for the room, sometimes, even the minimal array I select is too much. I think your light will be a great addition for when I'm in maximal mole mode.
Mosin
[Industry Expert]
Mar 11, 2012
895
13
930
I have the Littlite high intensity halogen version. If I had it to do over, I would have picked one of the LED types because the halogen lamps do not last very long, and they aren't particularly cheap. My suggestion is to avoid that model, and go with the LED at the outset. The halogen provides very pleasing light, though.
rad
173
53
1,585
Ohio
Hi Mike,
Ditto on the Koncept Lamps / i-towers, 1 one for the TT (red), 2 for the tape decks, (black floor standers ), & one for the chair.
rockitman
7,097
414
1,210
Northern NY
Those lamps just aren't tall enough for some of my racks with the TT's on top. I need a lamp to clip on the top shelf, hence my choice. I like the looks of those lights...wish I could use them.
Mike Lavigne
Apr 25, 2010
12,601
11,693
4,410
hard to imagine your tt is taller off the floor than mine, but I know you are a pretty tall guy so suppose that is possible. the I Towers are quite tall. and btw; if you wanted to shorten your Adona rack that is quite easy to do; just take it apart and have a machine shop cut down the legs, which I did. make sure they re-assemble the legs and align them as that part is a pain. but cutting them is easy with the right tools. lowering it allowed me to have it at the perfect working height with my Herzan.
for awhile I had my I-tower lamp on a large, thick, heavy maple cutting board to raise the level, although now it's on the floor.
personally I hate anything near the arm and like the fact that the I-Tower floor lamp is completely independent from the rack and plinth so I can get all the way around the tt for set-up for both arms. and it cannot fall off or get knocked off and cause havoc. yet I get great light exactly where I want it with a very wide range of motion. I can even bend it back on itself and get the lamp down near the floor for seeing the back of my dart preamp with bright light without holding a flashlight.
rockitman
7,097
414
1,210
Northern NY
I suppose I could prop up the base on some sort of box behind the rack. Is the illumination intensity adjustable ? ...dimming
Frank750
821
1
928
I use the same light. It's behind my HRS rack on top of 3 of the Nordost Odin wooden boxes. And I know you have some of those.
