I see they use no digital filtering - its effectively a NOS DAC, which means with no analog post-processing it will have HF droop to -3.2dB @ 20kHz on redbook material. Anyone come across its frequency response measurements to confirm?
Is 3db down at 20Khz state of the art? That should result in lots of loss sound for second harmonics of instruments playing even at 10Khz, thats not too good , and for $20K, oh well. Not that I am against tone controls, but given people over 45 or so already are way down in their hearing, this aint gonna help much with "air"...
And what about that happens at 22 kHz?
Perfectly fine with me![]()
I dont know who is going to hear a harmonic at above 22khz on normal music, what about it?
Redbook is slowly dying out and in 30 years will be just like LP is today, as Tim mentioned, the "in thing", atleast for a small sector of the audiphile population.
Hearts Heart album Gratest hits on CD sounds damn good to me. CD can and does sound good, NOS or over sampling or whatever. LP sounds good and so does tape. But man, I will not buy a source component that can not get the basics down in digital land.
Some folks think totally flat in the HF sounds annoying.
If you don't like the HF roll-off, you can oversample to 176k on the server side and get flat response but probably more ringing.
There are trade-offs. You could build a filter to compensate for the droop, but said filter would cause some ringing even if it were an NOS filter.
To me, it's an overblown criticism of NOS DACs.
Meaning you prefer the sound of droop to the correction methods you've so far heard?
Yes, Bruce.I will be using one at RMAF this year in the Usher/JPS Labs room.
