Living Presence
ddk
6,261
4,043
995
Utah
How does one use that alignment device on an SME 3012-R (circa 1981) ? There is no dimple on the pivot tower to put the nail point in for the pivot to spindle adjustment.
Please note that these are claims from the device manufacturer regarding the UNI-DIN curve and not universal truth. WhileBaerwald and/or Loefgren curves aren't optimum with certain tonearms(not sure if UNi-DIN is either) it has nothing to do with the groove bull crap and everything to do with arm's geometry. This contraption doesn't work with SME's sled base where you slide the entire arm to setup the overhang, this tractor works off a fixed point and you have to adjust the overhang in the headshell, opposite of SME's ingenious design. The Graham arm comes with it's own jig so you don't need it for that arm either. The Smartractor is just another alignment tool for the tool box and by no means does it render other protractors and curves obsolete.
Back to the Dark Side of Life …
….. Cartridge alignment needs great precision as 0.5 mm is too great an error. It is about getting the very best possible from a given cartridge/tonearm combination. To get that, the best possible geometrical set-up and alignment is the very first step. What is lost here to imperfect alignment can’t be recovered anywhere else in the audio chain. I want to illustrate the point by adapting the dimensions to our daily world. A modern stylus does feature a polished area – and it is actually that area alone which should have contact to the groove’s wall – of 1-2 ?m to 5-6 ?m.
A 12“ tonearm is approximately 300 mm effective length. Now what if we have an error of say one tiny 0.5 mm away from the calculated point of zero tangential error? No big deal and well within the tolerances of many alignment templates. Most “sweet spots“ on templates are already double that figure in diameter. Now let me transform those dimensions to our scale.
We amplify every figure in the tonearm and stylus by 1000x. Now the tonearm is 300 meter long. The cartridge now has the size of a big family house. And the polished area of the cartridge? It is now 1-2 mm to 5-6 mm. And hanging at the tip of a 300 meter long tonearm......... That 0.5 mm error we were talking about is now 50 cm - or 1?2 meter - off the perfect line.
You should know what to do to get the best out of the investment. Not enough, you should know what kind of Installation you want to have, depending on your records. There can be huge differences.
From 1938 to 2010 - nothing changed in more than 70 years? Phono tonearm geometry is born: 1937/38
In the years around the start of the Second World War, gifted engineers with strong backgrounds in mathematics published in quick succession their groundbreaking calculations for best approaching a theoretical tangential zero tracking error with a pivot tonearm. These calculations became the industry standard for years to come – though as I’ll explain later, they’re not the benchmark we should be using today.
Erik G. Loefgren and H.G. Baerwald published, in 1938 and 1941 respectively, the definitive calculations based on B. Olney’s initial essay in Electronics, November 1937.
They came to the very same best possible approximation of a circle segment to a given straight line. Their Euclidean calculations resulted in a tangential curve, which set the standard as being the theoretical and practical best geometric compromise. Phono tonearm overhang and offset angle were established as essential features in order for a pivot tonearm to reach the best possible geometry, thus giving the lowest derivation from the tangential ideal for that 70 to 95 mm of grooved radius in a 12-inch record. The final result was the best combination of lowest maximum and lowest average distortion in the tracking due to tangential derivation– or tracking error. The analytics of B.B. Bauer in 1945 and John Seagrave in the mid-1950s reconfirmed Loefgren’s and Baerwald’s theory and results, firmly establishing the tangential curve they calculated as the best compromise in geometric phono tonearm set-up.
This is an essential part of phono analog history.
The tangential curve of 1938/1941 – today named Baerwald DIN or Loefgren A DIN – was the indispensable foundation of high fidelity sound in phono records. The tangential curve calculated by these pioneers of high fidelity analog sound was mathematically as close to perfect as possible, and their contribution to the quality of phonograph reproduction can’t be valued too highly. However, the record groove Loefgren and Baerwald did their calculation for was not the record groove we (at least, most of us) play today – far from it. Aside from the mere outer dimensions of the medium (diameter), there are hardly any similarities in the two grooves.
Back in their day, the state of the art was the 78 rpm shellac mono record of the 1930s.The groove of a shellac mono record is different in most every way from a stereo microgroove record dating 1958 or later.
78 rpm shellac mono record vs. 33 1/3 stereo microgroove
The modern stereo microgroove is considerably smaller. Further, it is engraved with a much finer and more complex three-dimensional encoding. It runs with less speed, resulting in further reduction of available space for a given amount of recorded time. Likewise, the stylus and polished area are magnitudes smaller and more refined today compared to the days of Loefgren and Baerwald. So the stereo microgroove record is not the medium Loefgren and Baerwald faced in the late 1930s, and the modern 12-inch microgroove long-playing (“LP”) record is certainly not the medium they did their calculations for. The stereo microgroove is so different in most every way that it requires a closer look and a different approach to reach a possible optimum in sound decoding when tracking it. I had been using the original Dennesen Soundtractor since 2005: a solid metal device that allowed for Baerwald IEC alignment independent of the mounting distance. Most, if not all, better tonearm alignment tools available today are based on this ingenious design, which was years ahead of its time.
There are RCA Living Stereo LSC, Mercury Living Presence SR, EMI ASD, DECCA SXL, Columbia SAX, Impulse AS, Blue Note, Columbia 6-eye CS, 90 / 100 / 120 / 180/ 200gr gr. Vinyl, compresed Masterings…… and Reissues.
Many of these recordings have long grooves – cut fairly close to the paper label and thus often exceeding the “official” limits of both DIN (inner groove limit record radius 57.5 mm) as well as IEC (60 mm, measured from center of the record spindle hole).This fact inevitably means fairly high tangential derivation in the last minutes of many records – in other words, high distortion figures in those important areas of the music where you need/want it the least.
Why in those areas?
Say you have a 33 1/3 microgroove on an LP that is indeed spinning with a constant speed of 33 1/3 rpm. The beginning of the groove, at about the 145 mm point of the LP radius, features about 100 cm groove-space for one minute of recorded signal. That means lots of space and the best conditions for the stylus because its fairly easy going. (Imagine a straight new three- lane highway, early on a Sunday morning in mid-summer, and you get the picture.)
Close towards the inner label – say at the IEC limit 60 mm radius – the available space for one minute of engraved signal is only about 33 cm, squeezing the information into one-third the space, with an increased curvature and at a point where the tangential error of the tangential curve of Baerwald and Loefgren is in a steep rise. For the stylus of your cartridge this is no longer the three-lane highway it tracked 20 minutes ago. That highway has turned into a narrow serpentine in the Chilean Andes – a nightmare of a road that it has to drive with maximum speed, even while the edge of its chassis is hemmed in. What is happening in these last minutes where the conditions for the stylus get increasingly rough and tight?
In classical music – as well as in jazz and rock/pop –the final beats and the big climaxes occur exactly while the stylus is approaching the end of the groove. In other words, the biggest challenges for the cartridge tonearm happen just when the periphery conditions are the worst.
But this is just one of many facts that call for a slightly different look at the stereo microgroove. Since the mid-1980s, record manufacturing has more and more abandoned record-cutting exceeding a 62 mm radius, an evolution that actually began with lots of customers rejecting records because of inner groove distortion back in the early 1960s and that finally reached the direct metal-mastering era in 1984. The “modern” variation of Baerwald’s and Loefgren’s calculation (called Loefgren B IEC) – putting the two points of zero tangential error on the tangential curve (”null points”) closer together and the second null point farther away from the center – was tailored to this new trend in record cutting.
Superficially, this appeared to be a smart reaction to an altered condition. However, it remained an incomplete solution – only a fairly one-dimensional (over-) reaction to the generally decreased actual cutting radius rather than addressing the complexities of the situation. Baerwald’s and Loefgren’s calculations for a best possible combination of lowest average as well as lowest maximum derivation for a circle segment trying to approach a straight line with two null points can’t be bettered in our geometry. What can be bettered, however, is the resulting tracking distortion in a stereo microgroove. This can be done with a tangential curve that is not viewed under plain general geometric aspects, but rather under weighted criteria of the real – non-linear – medium.
Or you choose something different for the areas of higher and lower derivation which are positioned differently from Baerwald and Loefgren because they (if we add Stevenson and Loefgren B) paid no attention to at all: the human brain and our way of hearing. The human ear (actually the part of our brain that composes what we mean by hearing) is very sensitive to changes.
UNI-DIN’s curve is actually flatter than the other curves, in the sense that the inevitable dips and peaks of derivation in the tangential curve are smoother – less steep in both directions.
This results in less notable alternations – less notable for our brain – in tracking distortion.
Further, UNI-DIN features an unusual offset angle and overhang for the effective length. This results in less resulting skating force (I will cover this very specific topic in a later essay) with any cartridge and pivoted tonearm. (If in doubt, please check it out with your set-up – you will see that this statement is correct.) UNI-DIN offers more headroom in critical passages.
Towards the inner grooves especially there is much cleaner sound with more stable soundstage. Sibilants in female voices are much easier to handle and feature notably fewer tendencies to break up or become harsh and unnatural. Soundstage dimensions and depth are increased and more stable over the entire record. The sound in general is more relaxed and seems to have more headroom – the more the record is cut towards the label, the more apparent to the ear.
The differences depends also more or less to the country you live and their kind of voicing (Asia is different to USA, can match with classical recordings, not match with singers…)
And next, what tool for that? The majority are more or less copied from each other, more or less wrong, good for nothing, most are not tight fitted to spindle (they have no standard, some are smaller, some wider, this "forgotten" detail can ruin everything after 2s because it is wasted time
Or, what Arm will be used? Some (older ones) are made for 45's, some have a good geometry, some not, some can track everything, some not, can we compensate something with soft cartridges .... and so on and on...
Analog reproduction is a chain....
david
PeterA
12,669
10,942
3,515
USA
Thank you for that essay, Syntax. Fascinating information. Regarding your analogy of scales, what happens to overhang when an arm is raised or lowered by 2mm to compensate for the difference in thickness of a 150g and 200g record? Many people say, "don't worry, set VTA once and forget it." I have found that changes in VTA/SRA are much more audible that the resulting changes in overhang and VTF. And if one adjusts arm height for different records (depending on cutting angle and thickness), overhang and VTF in fact change less than they would if you never readjust the arm after initial set up. As you write, it is all about precision and compromise.
bonzo75
22,646
13,681
2,710
London
So, which arms and carts and geometry would be the suggestion for classical originals from:
Decca SXl
RCA Victor
HMV ASD
Similarly, which for reissues
Speaker's Corner
Classic 33 and 45
Analog Productions 33 and 45
I understand one of your suggestions would be Axiom, but would like to know others as well.
Syntax
259
307
970
At The Dark Side
A lot of questions ..... and decisions .... I do not want to write something negative about given Arms someone makes money with it, High End is a very opinionated business anyway. For anything mediocre there is a strong support somewhere and I am not interested to get in touch with those. Pain for Brain. Did that for - too - many years and closed that chapter. Sorry.
I am more interested to push the sonic curtain and to share a kind of information which can be useful or an advice to the user to stretch the Performance in a way which gives a good satisfaction. Specially in analog reproduction a lot of older information is more or less buried, replaced from opinions, semi-truth, marketing ....
Proper - or better - Alignment can be done with any Arm, there is a given distance Pivot to Spindle and a cantilever with a diamond
Anyway, Peter, yes I agree with VTA
This is probably the next step after chosen alignment (Nullpoint) but the differences in hight adjustment are more than only 2mm, probably 5+/- mm area. A Mercury has the hottest cut, here is the back of the Arm really down
That is the reason why a VTA adjustment is mandatory for superior sonic performance. RCA,SXL,Mercury, Monos etc. is always a step by step move to get the best soundstage. You can try with level Cartridge, the Sound is normally like a point source from the middle of your speakers with these records. Arm rear goes down and you "see" and hear that the sound between your speakers gets wider and deeper until a setting where no more changes are audible.
You can also give a Singer more "volume", Presence etc. when you know what to do and you have the technical background for it. The cartridges have no technical Standard, they have different cuts (diamond) ... it is an interesting chapter.
Reactions: Marcus
XV-1
3,619
2,629
1,860
Sydney
Why in those areas?
Or you could bypass all these compromised tracking curves and buy a linear tracking tonearm with true tangential tracking. Or a pivoted tangetial tonearm like Schroder or Thales.
no need to debate what % of tracking distortion on what part of the record sounds best or worst ;)
4,702
(...) Or you choose something different for the areas of higher and lower derivation which are positioned differently from Baerwald and Loefgren because they (if we add Stevenson and Loefgren B) paid no attention to at all: the human brain and our way of hearing. The human ear (actually the part of our brain that composes what we mean by hearing) is very sensitive to changes.
This results in less notable alternations – less notable for our brain – in tracking distortion. (...) [/FONT]
IMHO this is the critical and most interesting part of your comments - until we have quantitative models of the sensitivity of our brain to distortion and variation of distortion versus time, anyone can claim that is preferred alignment is the better one.
The work of mathematicians in the past was notable - they solved these problems analytically, a very hard job. However, considering current computing power of our desktops, using tools such as MatLab or similar any engineering graduate student can optimize geometries for a particular tonearm if we give him the model we prefer. Fortunately I am using a parallel tracking tonearm, I do not have to worry about such changes and can sleep peacefully ...
BTW, how many of our members use a spectrometer or distortion meter and a test record to check the perfect alignment the cartridge at null points? I read about it in the 70's in Hifi News and Record Review.
PeterA
12,669
10,942
3,515
USA
Indeed, I did just this last night when listening to a Melody Gardot LP. My arm had been set to listen to an Ella Fitzgerald LP and I was a bit lazy so decided not to raise it the 1mm that my LP notes indicated I should. Besides, most analog guys say "Don't worry, be happy" set and forget. Melody did not sound right. Her image was big, but the sound of her voice was small, a bit nasal, not present and breathy like I know she can be. So, to heck with conventions. I raised the arm 1mm, and wow. She materialized between the speakers in front of me. More focus, more presence, correct size image, but the sound entering the room became huge, more natural and real sounding. What a difference 1mm can make.
I understand that people don't want to go to the hassle of doing this. And I don't blame them. But, Syntax's posts are about extracting the best possible sound from a given system, particularly analog. And in this case, arm height for different LPs truly matters. I don't have the experience to know if this matters more for some cartridges than for others. Perhaps people's record collections have predominantly LPs which all fall into a very narrow band of cutting angles and thicknesses. But if they do not, it may be surprising to hear what a more precise set up for each LP can bring to one's listening enjoyment and involvement. Arms like Syntax's Axiom lend themselves to these micro adjustments and make it easier to adjust with ease, precision and repeatability.
4,702
(...) I don't have the experience to know if this matters more for some cartridges than for others. Perhaps people's record collections have predominantly LPs which all fall into a very narrow band of cutting angles and thicknesses. But if they do not, it may be surprising to hear what a more precise set up for each LP can bring to one's listening enjoyment and involvement. Arms like Syntax's Axiom lend themselves to these micro adjustments and make it easier to adjust with ease, precision and repeatability.
Perhaps some stylus shapes are more sensitive than others - I have a van den Hul cartridge, and although my preferred angle is not with the body exactly parallel to the record surface, I do not experience such differences in my system.
Repeatability is an issue in these matters. In one old report in a french magazine a few "experts" independently optimized vertical tracking angle using a Tri-planar tonearm - it was the arm to own at that time if were serious about VTA. Using the same recording they tuned it to very different angles, with differences over 3 mm. As far as I remember only two people selected approximately the same setting.
4,702
(...) it may be surprising to hear what a more precise set up for each LP can bring to one's listening enjoyment and involvement. (...)
Van den Hul thought about it in his excellent phono FAQ www.vandenhul.com/download/CAwdEAwUUkNHVkY= :
Q: Is it worthwhile to spend many hours in fine-tuning a cartridge / player combination ?
A: Yes, very worthwhile. Anything that you improve by fine-tuning improves the sound quality and that is a serious part
of the hobby. A hobby is something that you do yourself and not something that you can buy. By anything you do
yourself, you train your ears to perform better and to enjoy your LP replay even more. So don’t give up.
Syntax
259
307
970
At The Dark Side
The Axiom Anniversary 12“ Tonearm arrived
It is a true Tool for the serious audiophile who wants the best tonal reproduction in combination with EVERY Cartridge available.
The unit shows 3 micrometers for repeatable, unmatched adjustments during playing. VTA is obvious, but here you make your first alignment,
remember the scale data from Arm height and now you can try whatever you want without getting lost. You can always come back to your first setting.
Super for different originals (Decca, Mercury, RCA …)
Same for VTF
You do your first alignment with a given Cartridge, for example 1,80gr, remember the scale for it, leave your cart onto the gauge and you see exactly what number on
the adjuster will do with the VTF (1,803…1,792…1,834 and so on). You write a notice for that turn how much a half turn up or down will do and then you play
the record while changing VTF until it sounds best to you
Same for Anti-Skate
You need a test record for it (for first alignment), later while playing you can change AS a bit and you will hear the difference (when your System is on par for that)
The Arm itself throws a huge Soundstage, a very good Imaging in combination with holographic details.
My comparison with the regular Axiom and the Anniversary showed some interesting results. The Anniversary is a bit a faster and shows a different kind of physical presence.
I don’t know why, maybe the manufacturer did something and does not tell or the - better - adjustment showed that.
It shows details from my Cartridge and Records I did not hear before so clearly.
A Game Changer in analog reproduction.
Some Specs
Dynamic anti-skating non touch adjustment: on the fly during play
VTF (vertical tracking force) non touch adjustment: on the fly during play
VTA (vertical tracking angle) non touch adjustment: on the fly during play
Nano ceramic hardened titanium/carbon – composite armwand with internal liquid dampening on whole inner surface
Exchangeable inserts in counterweight tuned to cartridge’s compliance. Thus eliminating low frequency resonance peak.
Full radial/axial cardan shaft double gimbal bearing, using custom made to order German nano instrumental ball bearings of
aerospace grade with the lowest move friction possible today.
The arm wand is an unique composite of Titanium and Carbon with surface liquid dampening.
The mounting board, bearing houses, external and internal VTA tower and fixed headshell mounting are made from triple-tempered German AP70XX dural air frame grade aluminium and stress-relieved V2a stainless steel.
...and so on ...and on ... and on
Syntax
259
307
970
At The Dark Side
Ikeda Cartridge
Stunning ability to accelerate.
Excels at textural production in a large authoritative sonic picture with musical flow and a clean, ultrafast top end. No Cantilver, needs an Arm with top bearing, Energy transfer is key ...
The right Cartridge for the ruthless Audiophile, he can spend endless time for adjustments ...:D
But when done right, it is an amazing unit from the audiophile prime time in Japan.
Output voltage: 0.15mV (5cm/sec.45' 1kHz)
Load impedance: 1.0?
Reactions: GMKF and Mr Rickz
Syntax
259
307
970
At The Dark Side
After 10+ years of traveling and extensive Listening to various Turntables Basis Debut vac., Goldmund Reference, Kuzma XL, Rockport Sirius III, Seiki 8000 II, EMT's, Continuum Caliburn and some more I forgot I decided to go for this old Japanse warhorse and modified it.
Micro Seiki RX-5000 & HS-80
Out of its silent background, this Table re-creates startling dynamic swings. The music can literally explode from dead silence in an instantaneous yet progressive way that denotes the live thing. Here, the modified 5000/HS80 let the Lyra Olympos cartridge shine, both on macro and microdynamics. The modded Seiki provides a platform to recover the subtle shadings that create intensity in the music.
This modified version offers an extremely low frequency weight with an outstanding seamlessness top-to-bottom tonal complexity.
Outperforms easily the big Continuum Caliburn and the other ones in terms of low register speed, punch, definition, color, body, provides a much better resolution in the complete frequency band with noticeably more weight, 3-dimensionality and leaves the - overrated - ringing Seiki 8000II in the dust.
In a way, it is depressing. That design is 25 years old.
And it has speed adjustments :)
Passed the Sutherland Timeline Strobe Test
Lyra Olympos SL
This cartridge does something remarkable: it lets the music have the "WOW Factor" instead of the artificiality of a System. The sound is so dynamic that the music literally explodes out of the speakers and with the right recordings it will literally fill a room with a coherent, whole 3-dimensional soundstage full of air, space, ambience and lifelike energy. Very difficult to amplify to get the glorious Picture.
Frequency range: 10 Hz - 50 kHz
Cantilever system: Diamond coated boron rod cantilever and natural diamond, Ogura-manufactured. LYRA original line-contact stylus (3 x 70 micrometers profile).
Channel separation: 35 dB or better at 1kHz
Internal impedance: 3?
Output voltage: 0.2 mV (5.0cm/sec., zero to peak, 45°)
Cartridge weight (without stylus cover): 13.8 gr.
Compliance: Approx. 12 x 10-6 cm/dyne @ 100Hz
Recommended tracking force: 1.65 - 1.80 gr.
Recommended impedance: 100? to 47k?
Reactions: Mr Rickz and Bodhi
16,216
13,681
2,665
Congratulations!
Bodhi
1,051
361
155
Congrats Syntax on your classic Micro Seiki deck! :cool: I just had a couple of questions...
Firstly what mods has it had? And did it come modded, or did you carry the mods out yourself? Also, how do you think that deck would compare to the current generation, eg: Tech Das AF3P?
PeterA
12,669
10,942
3,515
USA
Syntax, I have been following your progress from old days on Audiogon. You have always taken very good photographs and explained your changes very clearly. That new Axiom looks well made and certainly very adjustable with German precision. I notice that the later posts with the Ikeda cartridge uses a different headshell from the adjustable ones in other photos. Also, the Axiom is not in the latest photo of your turntable.
So, I am confused about exactly what combination you now prefer of cartridge and tonearm. I have also spoken to you many times about Vibraplane. I recently deflated my units under both amps and turntable. The black background is slightly less so images and dynamics are less stark and bold, but harmonics and information like hall sound and ambience seem to be improved. How would you describe the way your sound changes when you deflate your Vibraplanes? Do you still have them under your Lamm amplifiers?
Syntax
259
307
970
At The Dark Side
There are 2 ways to get Superior Sonic Performance
The usual one
and the better one
adjusting plates for every Arm and every Null Points available
