My understanding is that there is an ONT in the garage, but a modem in the house.
Hi again. thanks for asking that. When I first received the M12, it was missing the two extra cables to insert it between my modem, Nucleus+ and both cat 8 cables to my streamers. So I actually DID put it right in front of my Aries G2.1 It sounded amazing. But I need a switch after my modem, so that is where I 'thought' it was most indicated (replacing my Bonn N8 switch). I am not sure it sounds as good as just on front of the Aries, just seemed silly to put a switch where I did not need a switch (extra ports). I actually do have trouble with my Aries disconnecting and 'not being found' on my network. I have to cycle the power sometimes a bunch to get it to connect. Is it the EtherRegen? I have also heard use the A side of the ER may help. Currently it would not reconnect and frustrated I just turned it all off and went skiing for the long weekend. I will try different arrangements, and am open to suggestions PLEASE. One idea is to put the N8 switch back in place, and move the M12 to my listening room as you suggested already. Disadvantage of this is it takes the M12 out of the chain for my second system. Also it adds a power supply and a M12 flower of cables in my audio room, not my computer room. Ideas please!
Hello all jumping in here. I want to do this correctly and appreciate the responses.
1) consensus seems to be remove EtherRegen from between M12 and Aries G2.1 streamer. ?Yes
2) debate on whether Muon should stay or go between M12 and Server?
3) in a sense don't I have M12 in front of Aries? And directly if I remove the ER and the Muon?
-because M12 is upstairs, there is 20 feet of Supra cat 8 between M12 gold cable and Aries. Wrong place still?
4) I use no wall plates; I have JCAT NET ISOLATOR (Coupler) between M12 cables and Supra Cat 8 runs through the wall at both ends.
5) Should I replace the M12 gold with my Bonn N8 (put it back) and then place the M12 MOST DIRECTLY in front of Aries Streamer?
- This ELIMINATES M12 Gold switch from the chain to my upstairs system, but perhaps a fair trade if this improves my main system.
6) yes fiber is an option but trying to avoid more stuff!
