You would have criticized him whether he compared it to the Arrakis or not. Jeff made the right choice by not unfairly comparing the two speakers. Sure, it would have been great to have the Arrakis onhand for the Q7 review, but I honestly do not believe the room would have supported all that weight. As far as Robert Harley goes, can you find me one of his reviews of a super speaker over the last year that actually draws a single comparison? Until you can, this is a personal attack against Jeff and nothing else. The moderators should do more to clean up the board.
Remember, the current Arrakis is now an active speaker - bi amplified with an active crossover between the 15" woofers and the rest of the speaker ...
yI wouldn't say they're active speakers: there's no internal amplification
They require, instead, an active multiamplification.
What is the rationale for electronic crossover vs passive...so that i t can be adjusted in the field for optimal setup? How does the hook-up work? Lets say you have 2 sets of monos...one set for High frequency/mids and the other set for bass. Does the preamp go to the crossover, then signal is split by the crossver to go to the 2 sets of monos?
Presume one could do this with 2 dual-mono amps instead? In other words, each dual-mono's LEFT channel would cover the LEFT channel high frequency/mids or bass. Each dual-monos RIGHT channel would cover the RIGHT channel frequency/mids or bass. Yes?
(...) The Q7 sounds very much like the Q5 but everything is so much better by a very wide margin. The ease with which the Q7 can reproduce music is almost in the level of the Magico Ultimate (...)
I had the same feeling when listening to the XLF with my recordings - how could it sound so much better than the Maxx3 I had long experience? We all would hope that the law of diminishing returns would make the differences small, but they are really large. And you are spot on - the "easiness" is a key point.
I would like to bring the attention back to amplification. What amp(s) would suit the Q7 best. From what I understand Alon is using Constellation Audio Centaur Mono amps in the Magico showroom. One would think that the Hercules would sound even better. Personally I have heard great things from other Magico speakers with darTZeel NHB-458 and Soulution 700. I also notice that the Q7 has been auditioned with great results with BAlabo and FM Acoustics and with not so great results with Pass Labs and Spectral. Of course none of these Q7 auditions were my own.
Thanks,
Roysen
Unfortunately, I saw the Q7s but didn't hear them. They were on display at the front window of a store at Adelphi. Stranger still, at the MOD DAC show the Magico dealer had a killer system on display with Q1s, Q3s and a VAC Statement. They treated the room too but they were not cabled! How weird is that?!!!!!!
