I know you're not a fan of rhodium plating, but the truth is the base material and the quality of the plating make a massive difference.
The standard connectors you had replaced are NOT Furutech. The objections you have to the sound of the plugs have NOTHING to do with Furutech plugs or how they might sound.
This are rica in copper 7N Platinum plated
Thank you, Marty, for this very interesting and important report! I am glad you are finally at peace with your Masterbuilt Ultra interconnects!
As I am on the verge of ordering some Masterbuilt Ultra speaker cables and Ultra interconnects I somehow will have to make a decision on the XLR connectors.
Marty, did the Masterbuilt people balk at having to attach the Bocchinos, or are they connector agnostic and happy to indulge custom customer connector requests?
Did you send the Bocchinos to Masterbuilt or did Masterbuilt acquire the BAXLR connectors themselves?
How would you suggest someone go about choosing between the gold Furutechs and the silver Bocchinos?
Is there anything you are able to report about your comparisons between the MB Ultra interconnects with gold Furutechs or silver Bocchinos and other interconnects you may have in your cable inventory?
Perhaps Leif can tell us if you are the first person to have asked Masterbuilt to use Bocchino XLRs, or if others have also requested Bocchinos?
I know MasterBuilt had to modify the Bocchino XLR connectors to allow for the amount of conductors used in the Ultra.
MasterBuilt told me they had to actually cut the back part of the plug so they fit. But I have never seen the the conductors for the Ultra XLR.Am surprised to hear that Leif as the Bocch xlr accomodate @10awg / 5mm sq, which is power cord level for many.
Dave, according to MB, they are indeed Furutech XLRs OEM'd for MB. Totally agree with you about base metals and quality of plating. Not sure I want to try and figure out all the possible permutations of these that are out there. The Bocchinos are quite satisfactory. I have other places that call attention to my OCD!
Marty
Ok, well I just want point out they are NOT Furutech CF-601 or CF-602 XLR Plugs, therefore your experience with whatever MB uses does not translate to the CF-601/602 that I use. I don't find them to have the same issues you do.
http://www.furutech.com/2013/01/27/1081/
https://www.masterbuiltaudio.com/ultra-line-audio-cables?lightbox=dataItem-ipkb97og
They are not the CF's Dave. We tried the CF's and prefer the OEM plugs better. Notice the hollow pins.
Saying that though, for an 18k cable, I would have designed and produced the connectors specifically to match the conductors.
Rgds,
Paul
Dave,
I'm pretty sure that my reterminated gold XLRs use the FP701 and 702 Furutech XLR connectors.. Leif can confirm if he wishes. Sorry, but statements like "not even close" are hyperbole to me. Did you really compare the Furu gold connectors to the Furu rhodiums with the connector change as the only variable in an otherwise identical system with the same exact music sources used for comparison? If so, I extend my congratulations because that is serious work. If not, there is still no wrong here. You and many others prefer the MB rhodium connectors. I do not. We all do what we need to do to maximize our musical enjoyment. BTW I think Bocchino also makes a platinum plated silver plate over copper XLR but I have no interest in trying those as the "standard" Bocchino silver XLRs are is quite satisfactory. Happy listening to all.
Marty
That is the B3 model - 10cm long and @5 oz per plug. The locking ring exerts so much torque that it is capable of crushing a pcb mounted rca jack. Luckily the grip is still very tight without it and the ‘junior’ B33 model offers a more practical and better priced proposition.
Dave,
Marty's experience is what it is, and not typical for all Rhodium plated contacts, though we are all aware that Rhodium can be quite devisive in respect to what it does to the sound. However, the Bocchino are the best sounding audio interconnect terminals I have used, my 2nd are the Furutech.
Rgds,
Paul
IMO, WBT are the best... platinum plated silver. But they don't make XLRs.
