I´m going to use mine in combination with either a Wayne Audio ring or another beauty in brass I got from Spain
I’m sure most will find the CU 180 as an upgrade. It is the highest price option for the least features however (such as it is pretty thin and has no slope).
Nope. Doesn't bother me at all. Weights are cheap and effective.It certainly is an upgrade. I use one each on my SP10 mk3 and Exclusive P3. Being flat is an advantage as I don't use a clamp/record weight. My various weights just sit on another shelf as I prefer the record naked.
Can you even use a sloped metal mat if you don't use a clamp/weight?
Nice. That is what I am missing from my Kenwood.I got cnc´d an acrylic centering disc that fits inside the upper part of the ring and a flange that hangs outside the ring, which makes it possible to center "on the fly"w/o stopping the tt
playing with it now directly on top of bronze platter....deinitely speedier and more dynamic
no slope on this one but I have peripheral weight and center weight
wouldn´t you like to take over that one....![]()
where did you source this?
sry misunderstood...the 2 x CU-180s I found in Japanwhere did you source this?
