METAXAS Tourbillon T-RX
I´ve tried several modded A80 reproboards,including tapping signal after eq at R47 and running custom tubed buffer, but theese are by far the best sounding; quieter, better resolution and more relaxing......particularly in SE direct out mode
Thank you for your reply! Have you tried the direct output connection with an external head preamp? I am sure you know Sepea makes the daughter boards with connectors, perhaps someone else does too. I need to look what that R47 is, from your description it sounds pretty clear though.
I use the Sepea boards on my A80. What is the current price for the playback only solution?
