MSB Select DAC II. The way every DAC on the planet should be built.
Some people here seem to have thinner skin than the Hfiman 1000 Nanometer Diaphragm https://youtu.be/fzyDw9o0pzQ and in the case of Blizzard see ferocious giants where there´s only windmills, this is coming from a just arrived outsider with no affiliations here. Some of you are rude and disrespectful and try to blame Blizzard for stirring things up when it´s your own intransigence that give this and other threads the perfume of sulphur. Agree to disagree and move on, even certain Amazonian tribes who´ve barely seen other human beings know of your disregard for anything Blizzard and this antagonism is unfair, I doubt any of you would endure such treatment without lashing back with profanity.
Wisnon I will give the (Bjorn) Borg regards on your behalf ;)
Can you hear yourself? "the ones who oppose my ideas" You don't have ideas, you have statements of truth that are hard......there is no opposition to your ideas....because you think you have "THE TRUTH". This is where the battle lies.....in yourself. The "truth" is infinite. You cannot possibly hold it in your mind. It exists in all people and in all things. Other people know just as much if not more than you do about anything and everything. The truth is that you know nothing......I certainly know I know nothing. It may be a bigger nothing than some others about certain things.....but it is still nothing. We are nothing without Love and love includes everyone.....it does not exclude.
I thought you were done with this thread?
I am your mirror. This mirror loves you. Your personality....well, it could use a little tweaking. Maybe a couple of "magic tubes" would sweeten you.
Well I'm 100% open to anything that can be preformed on a PC to make the hardware end as simple and pure as possible. Now that I've decided to go 100% chipless DSD, I want to learn all I can about filter algorithms that can be handled on software the make the best out of it. Jussi and HQplayer has really opened my mind to the possibilities
. Perhaps you should start a thread we can discuss software based filter algorithms in detail?
The method I was proposing would disrupt here too many people's little back garden - the various Trinity, DcS, MSB...
and it is also too technical for many users.
Well perhaps there's a dark corner somewhere in the back of the forum, that wouldn't cause too many tears to flow if this topic was discussed in. :) Or if there's another forum you know of this would be better welcomed, let me know :)
When I posted the reply I got a message stating that my post needed to be approved by a mod, don´t really know why.
Thanks for the support anyways. Did you send it today, or yesterday at 12:52? PST
Thanks again for being one of the few that has the ability to acknowledge the real issue here.
I must say that's some pretty thin skin! Ha ha!
How is it not true? Half of the Lampi components are simply DIY modules from third parties. Let's look at the Amber for instance, it's just a budget DIY 9018 kit from DIYINHK:
http://www.diyinhk.com/shop/audio-k...ume-control-and-spdif-inputxmoses9018k2m.html
a DIYINHK USB interface:
http://www.diyinhk.com/shop/audio-kits/58-xmos-dsd-dxd-384khz-high-quality-usb-to-i2s-pcb.html
With a fancy tube output stage, and power supply plunked in a case.
Now look at the innards of the gg and tell me what you see? Amber is unlike any other lamp dac. Even the receiver chip is heavily modded on most lamps, as well as other parts. the way the dac chip is implemented is never standard...
Resistance is futile…you have been assimilated!
Don't get me wrong DIYINHK makes great kits for the price. I picked up this AK4490 kit from them. Supposed to kill the 9018 unit. My intentions are to build it into a portable battery powered unit with Hypex class D amps and Scan-Speak full range drivers. But just haven't gotten around to it. I have a Dexa Discrete opamp for it. Still haven't listened to it though.
Just do it and see. Dont prejudge.
See, its theoretical stuff related to this I wanted to chat about. Primarily your active system project and how you intend to implement it. BTW, non-technical me hates opamps in Dacs. (yes, I know not all opamps are created equally).
Wisnon this is part of his design philosphy..
I have always designed my speakers to have a flat response at the listening position
Flat at listening position is terrible sounding. If thats what he likes , no bass , shrill treble ..so be it .. how anyone can evaluate a dac under such conditions is beyond me.
You probably hate IC opamps. This is a discrete opamp. Big difference in sound. But 50x the cost of the IC opamp this DAC came with, the NE5534.
http://www.mouser.com/ProductDetail...=sGAEpiMZZMtCHixnSjNA6Mrdwin7F8A2yVUSSpLzDF4=
http://www.partsconnexion.com/opamp_dexa.html
I explained that to you already. It obviously went in 1 ear and out the other. Or else you never even read it.
Yes when you have a speaker like yours with a single 5" mid running from 220hz up and a skinny baffle, no wonder you need your "house curve"
Those 11" side firing woofers running up to 220 Hz simply won't give you the coherence between 100-350 hz at the listening position without your "house curve"
I don't build speakers like that anymore. I do everything in pairs. 1 to cover the full range up to the tweeter, and the other to cover the baffle step diffraction. And I never go from a 5" right to a big woofer, especially side firing. I'll always go to dual 7's, then a big woofer or 2.
Spin it anyway you want .. not one designer can or would design a speaker to be flat at listening position , and if thats the sound you are aiming for..good luck...
Lawrence Dickie should have taken advice from you when he designed the G1's .. they are obviously rubbish..
Never said they were rubbish. But no matter how good of a designer you are, your not gonna be able to defy the laws of physics. There's different ways to do things, he did things his way, and I'm doing things my way. I've been building speakers for 20 years and not a single person who's ever heard, or bought speakers from me has ever said anything but they are stunning. I have guys calling me up that I sold speakers to 15 years ago who say they will never sell them, still the best they heard. So I don't need verification from you on how I should be doing things.
