I've had the MSB Select II in room for less than 3 days. I've heard nothing that would suggest it's not going to exceed all of my most positive expectations. I've never heard any digital close to this. but it's too soon (and is it ever the right time?) for pronouncements or anointing anything. we have enough people throwing those terms around that we don't need me to do it. and I've not heard a number of the suspects on your list such as the Aries Cerat, Origine and others. while I've heard the Vivaldi stack at shows it's been a few years now and I've not heard the v2 upgrade. and then there is context and all that so the whole 'which is best' is a troubling thing to get into. obviously I did 'vote' with my checkbook, so there is that.
and I have much work to do here to find the best of the Select II. I need to compare inputs between the XLR and RCA, then need to compare the USB and Ethernet approaches too, and then optimize the cables for each of those choices. then i'll be where I can see just what it can do.
and honestly; for me personally the only test that matters to me is the real one; how does it stack up against the truly big guns?.......my vinyl and tape. none of those other digital choices matter.
right now it's easy for me to say that what I've listened to these last three days exceeds the performance of any digital I've ever heard by a good margin, including the Select II at shows. but that does not really help us to answer your question. and even the Trinity dac did not have the same server so that is a variable.
yesterday I spent 5-6 hours straight just listening to redbook. and it was revelatory.....remarkable. and this is simply bit-perfect files from the SGM through HQ Player and Roon. it was stunning really. this is with a generic USB cable and modest interconnects. it's said that with the MSB transport and their i2S interface that discs outperform files. but they don't have an SGM/HQ Player to compare. so that also is a question I need to resolve. are discs better or not?
Would you say at this early stage in your evaluation of the Select 2 that you are at a similar level of musical enjoyment and evolvement that your vinyl and tape provide you?
Cheers.....
