Select II + darTZeel = awesome.
it's possible you could even use the 'zeel' 50ohm interface directly from the Select II to the dart 108. I'm working with Vince about that. the whole MSB 'less is more' engineering approach where eliminating compromising circuitry is key to finding the music, exactly mirrors the darTZeel approach. both companies have very low noise, but no global feedback or strangling of the musical flow.
I can't say how the dart 108 compares to the MSB amps since I've not compared them directly; but perceptions from shows it's of that same sonic direction.
and yes; there were 2 upgrades to the 108. back in 2005 it went from 'A' to 'B' and it became more stable into loads and an added XLR input.
then 2009-2011 the SNCP upgrade made a huge difference in power and controlling speakers. almost any 108 is a 'B' and has had the SNCP upgrade.
Mike
As always thanks.
The DartZeel have always been of interest to me based on design philosophy but I never had reason to really consider until now.
The 50 Ohm interface is a DartZeel pre to amp interface "meant" for best interface of DartZeel products, correct? So Vince is asking the factory to try something to take advantage of that? That would be awesome?
To date, you haven't tried direct from the Select II to your dual mono DartZeel, correct?
We are on an interesting ride indeed. I continue to be blown away by Select II. I'm glad I heard about this upgrade in firmware. We should email Vince and have MSB let us know about such things.
Will try it tonight when I get home.
Howie
